Page 1 of 3 1 2 3
NEW BEST-CC event Columbus #699809
05/16/10 06:45 PM
05/16/10 06:45 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
I am sure there will be several "new bests",,,thought i would post mine.
I blew the motor up LAST YEAR at Bowling Green ,,,,and had it re-done over the winter,,nothing fancy,,,re-used my E heads,,,,and changed the cam.
Previous motor was awesome,,(440, solid cam, E heads, 13:1) ,ran well,,,low maintenance,,,and i had tons of runs on it,,,,no complaints,,,
Porter Racing did the new motor, short block,,,451, solid cam, 13:1 E heads,,,made 650 HP and 580 tq on Dwaynes dyno..........
Best ET LAST year was 10.26 @129 @ Norwalk with a DA of 600,,,so i was hoping to get close to that with the new motor.
Just got the "new" motor installed this week,,,and fired it up 2 days before leaving home............
Got to the track Friday,,,for the first run ,,,, Car went 10.21 off the trailer,,,, woo hoo...NEW BEST ,,, first run,,,,MPH was about 130....
Second run,,,,10.23 with a drop in 60',,, very happy,,,,
Saturday AM,,,,nice and cool,,,,,,did some minor adjustments....expecting some more 10.20's.......
First run............ 10.12 @ 131.3 !!!!
Second run 10.14 @ 131 YIKES,,,,,,,,, didnt see that coming....
This was with a 1.44 60',,,, ( best 60' in the past was a 1.40)........ so.......there might be a little more.
Was with Mr P body and Labratt,,,, got some suggestions on the suspension,,,that might help....(Thanks Mike and Randy)
Also noticed my slicks are SHOT......... no wear hole to be seen,,,,,,
so,,,,new set of slicks,,,and some front end "tweeking",,,might help even more....we'll see....
Very happy with the results,,,,was hoping the new motor would run a 10.26 or close,,,,,,but thrilled to get a 10.12 @ 131MPH
I put all the motor specs,,,,,(FYI),,,if anyone is interested,,,,nothing to hide,,,,
1965 Plymouth Belvedere
(updated 4/2010)
-New motor from Porter Racing 451, tall fill with hard block. .055 over.
Ross dome pistons
BME rods
Ohio crank, stock stroke 4340
Comp Cams flat tappet cam, nitrided, 304/304, 272/272, 108 LSA, 650 lift w/1.6 rockers
Cam lash = .020 HOT **
Compression around 13:1 (
Indy 1.6 rockers
Victor 440 intake
Holley Dominator 1050HP
Supersucker 4 hole spacer
TTI 2” x 3.5 nickel plated headers
MSD digital 6plus ignition
MSD crank trigger
MSD billet distributor
Edelbrock heads (ported by PRH)
Made 652 HP @ 7200 RPM,,,,and 564 tq at 5800 RPM on PRH dyno 38* timing
NGK plugs (V power 9 R5671A-9 ) **
Firecore wires
Dana 60 w/ 4.56 gears
Wilwood disc brakes x 4
Caltracs, rancho -9 shocks, QA-1 front shocks
Bondo Bob K frame, motor ears, limiter, steering link, modification
CRT trans with Griner valve body, CRT clutchs, (installed 8/09)
Turbo Action 8” 5800 STALL re-done by TA 6/07
31 x 10.5 x 15w M/T slicks (13-14 lbs)
29” front runners 30-35lbs
Timing 38*
Weight of car 3260 w/out driver
Oil Filter Wix
Brad Penn oil ( 20/50)
NOTE: plugs are INDEXED *******
ps,,,,THANKS DWAYNE,,,,,,
Re: NEW BEST-CC event Columbus [Re: 69CHARGERMD] #699810
05/16/10 06:50 PM
05/16/10 06:50 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Awesome, congrats Doug!!
Re: NEW BEST-CC event Columbus [Re: ProSport] #699811
05/16/10 06:57 PM
05/16/10 06:57 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
It was good to see you Doug, glad to see the car out performed your expectation's,,new best's alway's make you feel good.
Re: NEW BEST-CC event Columbus [Re: 69CHARGERMD] #699812
05/16/10 06:59 PM
05/16/10 06:59 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Good to see you Doug,
Those are some stout #'s for "small motor 451"
131mph , I think some high 9's are coming.
Good Job
Re: NEW BEST-CC event Columbus [Re: dartman366] #699813
05/16/10 07:00 PM
05/16/10 07:00 PM
tboomer Online work
tboomer  Online Work
Nice job,Doc!! You can always count on Dwayne to do a good build!!
Re: NEW BEST-CC event Columbus [Re: ProSport] #699814
05/16/10 07:04 PM
05/16/10 07:04 PM
Dana Point, CA
Fast Yeti Offline
Fast Yeti  Offline
Dana Point, CA
NICE...! You will tickle the 9.s before the season is over.
Re: NEW BEST-CC event Columbus [Re: 69CHARGERMD] #699815
05/16/10 07:09 PM
05/16/10 07:09 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
must have been those Firecore 50's and the super sucker.....
wont be long now till youre knocking on another door!!(9's)
congrats Doug on your new bests
Re: NEW BEST-CC event Columbus [Re: smokinwoody] #699816
05/16/10 07:18 PM
05/16/10 07:18 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Good to see you doug,,,That good running hot rod you got
Re: NEW BEST-CC event Columbus [Re: 69CHARGERMD] #699817
05/16/10 07:34 PM
05/16/10 07:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Lookin good and you know the drill....test,test,test....
Re: NEW BEST-CC event Columbus [Re: Thumperdart] #699818
05/16/10 07:39 PM
05/16/10 07:39 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Congrats Doug
It was good to see you guys
Re: NEW BEST-CC event Columbus [Re: VernMotor] #699819
05/16/10 07:41 PM
05/16/10 07:41 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
wow that is awesome Doug.How was the 1/8 mile ET/mph. wow between you, wild bill, tom, Ron all building new and awesome engines. it looks like i better just leave my car at home lol.Bobby
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: NEW BEST-CC event Columbus [Re: 69CHARGERMD] #699820
05/16/10 07:52 PM
05/16/10 07:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Was good Doug.... good to see you again... a few little
tweaks and you will be in the 9s
Re: NEW BEST-CC event Columbus [Re: 69CHARGERMD] #699821
05/16/10 07:57 PM
05/16/10 07:57 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
Congrats Doug! Can't wait to see it run.
That is too funny that your car is 3260 because that's what mine weighed exactly a few weeks ago on the scales. I am hoping to get it lightened up a bit with some wheels/brakes in the near future.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: NEW BEST-CC event Columbus [Re: MR_P_BODY] #699822
05/16/10 07:57 PM
05/16/10 07:57 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Congrats Doug, I saw your car there but didn't get a chance to talk to you....Good looking car!
Re: NEW BEST-CC event Columbus [Re: 69CHARGERMD] #699823
05/16/10 08:04 PM
05/16/10 08:04 PM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
Nice work Doc..
You deserve it...Work Hard, Play hard. .
Re: NEW BEST-CC event Columbus [Re: Bubba] #699824
05/16/10 08:09 PM
05/16/10 08:09 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
Nice work Doug, you'd have broke into the nines with a couple of bottles of that sure grip lube I had....
Re: NEW BEST-CC event Columbus [Re: todd440] #699825
05/16/10 09:06 PM
05/16/10 09:06 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
The Doctor is knocking on the 9 second barrier !!! Awesome.. I see that happening this year at Norwalk, if not sooner... Nice job.. Your list of friends helping should be on everyones list... Great guys.. Congrats, Doug. You've worked VERY hard for it.. Congrats..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: NEW BEST-CC event Columbus [Re: sunroofgtx] #699826
05/16/10 09:32 PM
05/16/10 09:32 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I stopped by your trailer in the pits and didnt see ya....Wanted to say hi...so ......HI....LOL
Congrats on the new best, car looked great. I put both hands on the roof as I gazed into the driver window, after that you was rewarded with a new best...what can i say
Later
Bob
Re: NEW BEST-CC event Columbus [Re: 69CHARGERMD] #699827
05/16/10 09:43 PM
05/16/10 09:43 PM
Whitey Nocar Offline
sweet!!!
Re: NEW BEST-CC event Columbus [Re: Whitey Nocar] #699828
05/17/10 12:18 AM
05/17/10 12:18 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Dougie,I really think if you can get some .840" race bars,running the Calvert shocks,and puttin' on a new set of slicks,you'll be seeing some 1.35 60' times and most likely high 9's! Your new motor ran great! Kudo's to Dwayne! As always,it was great hangin' with you(and Raff)this week end! We had a GREAT time! Now if I can just curtail that snoring of his!!!... I'll get in touch with Gary Jacob and see if he can dig up a set of those bars for ya! Talk soon,Buddy! RandyB BTW...the part # on those bars is P5249156.
Page 1 of 3 1 2 3
