Would you buy a used race-cam ....?? #699725
05/16/10 05:53 PM
05/16/10 05:53 PM
Florida STAYcation
dOoC Offline OP
The village idiot's idiot
dOoC  Offline OP
Florida STAYcation
If no ...why not ? ... If yes ....what would you check for? (other than a completely FLAT lobe)
Re: Would you buy a used race-cam ....?? [Re: dOoC] #699726
05/16/10 06:09 PM
05/16/10 06:09 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Well it is do you trust the guy your buying from? Thats the only thing you got to go on. You could get a good deal or you could get stuck. You won't get your money back if you find something not to your liking. I've bought 2 cam and lifter up grades with no problems from fellow moparts members.
Re: Would you buy a used race-cam ....?? [Re: dOoC] #699727
05/16/10 06:13 PM
05/16/10 06:13 PM
MotorCity
RC91 Offline
RC91  Offline
MotorCity
No, unless it came from somebody I know and I've seen it in action and know it's history. Buying a used cam from a online auction or a swap meet, there is no telling what the specs really are.
Re: Would you buy a used race-cam ....?? [Re: dOoC] #699728
05/16/10 06:55 PM
05/16/10 06:55 PM
AndyF Offline
AndyF  Offline
I sell cams all the time, never heard of anyone having a problem with them. I go thru a lot of cams during dyno testing so I might as well make people good deals on them.
Re: Would you buy a used race-cam ....?? [Re: AndyF] #699729
05/16/10 07:24 PM
05/16/10 07:24 PM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
Cool Andy ...whatcha' got ? ..
I am looking for a cam for my boat ... in the range of .530 to .600 lift.... with a "wicked" idle. And something that will run-up-to about 7500.
There is a rat-motored jet boat on the lake here that I want scare-off !
WHY don't any of these manufacturers put any kind of part #'s on these sticks? ALSO ....I have heard of a LOT of different pricing on used cam a lifter packages .... is 1/3 of typical-retail about right?
Re: Would you buy a used race-cam ....?? [Re: dOoC] #699730
05/16/10 08:36 PM
05/16/10 08:36 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
AndyF is definitely one of those people I would buy a used cam from but there are not too many i would. Jet boat hugh? He will be way down on power with a jet. Supposedly takes about 30% more power to run a jet due to inherent design deficiencies compared to a prop. They make a nice rooster tail but that is about it. He must have a very hot engine if you think you need to turn 7500 in a boat. Tell us more. Boating is my favorite subject.
Damon
Re: Would you buy a used race-cam ....?? [Re: dOoC] #699731
05/16/10 09:23 PM
05/16/10 09:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A roller cam yes.... the others no
Re: Would you buy a used race-cam ....?? [Re: mopardamo] #699732
05/16/10 10:12 PM
05/16/10 10:12 PM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
md .... Well ...a big ole Rat motor has a little more power than a 383+30. so I figure we are about equal ... him with a jet ...and me with a V-drive. My need for a motor that will run-up-to 7500 ? ... just in short bursts.
Oh ...and there are deficencies with a V-drive. There is something like a low-speed WOT "slippage" of up-to 70% ... and high-speed of something like 30%.
My boat here is just an old Stevens shovel-nose hydro(fiberglass) I picked-up off eBay some years back. This rat-motor-guy has got me "hot" to get the boat done ...PLUS there are some real NEAT happenings up-here on some big lakes .... like Houghton and Torch Lakes.
All I want to have is something that will cruise all day long and will have a little PEP ...outa'-the-gate and upstairs a bit. Something way diff I am doing is to run a CLOSED cooling system that will be hooked up to the V-drive. The headers will have a separate system for lake-water-cooling and to "muffle" the noise also.
Re: Would you buy a used race-cam ....?? [Re: MR_P_BODY] #699733
05/16/10 10:18 PM
05/16/10 10:18 PM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
Yo P .... you would recommend a roller-cam for my application ....or only BUY a used roller ?
Re: Would you buy a used race-cam ....?? [Re: dOoC] #699734
05/16/10 10:19 PM
05/16/10 10:19 PM
ill
dennismopar73 Offline
ill
the only way i would it would have to come from someone that i know
otherwise never buy used cam
like used converter you just don do it
Re: Would you buy a used race-cam ....?? [Re: dOoC] #699735
05/16/10 10:23 PM
05/16/10 10:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
IF I were to buy a used cam it would ONLY be a roller,
never a flat or hyd....... JMO
Re: Would you buy a used race-cam ....?? [Re: MR_P_BODY] #699736
05/16/10 10:24 PM
05/16/10 10:24 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Ditto...Have done so many times. Look for gouges or score marks.
Re: Would you buy a used race-cam ....?? [Re: dOoC] #699737
05/16/10 11:06 PM
05/16/10 11:06 PM
It depends, I have bought quite a few used steel roller cams, some injured and the some not . As far as a flat tappet cam(solid or hydrauylic) it would really depend if it was in the car and I could make sure the lifters where mark on te lobes they came off of and I got to measure the lobes of the cam for lift before buying it The second thing is to check the bottom of the lifters for wear marks, flat or ruined lifters and so on, probally best to not buy a used one of those on second thought
Re: Would you buy a used race-cam ....?? [Re: MR_P_BODY] #699738
05/16/10 11:14 PM
05/16/10 11:14 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Totally agree!!
Re: Would you buy a used race-cam ....?? [Re: Moparnut426] #699739
05/16/10 11:40 PM
05/16/10 11:40 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
bought my solid mopar .528 from a member here with lifters in order and i'm happy. wouldn't buy a flat tappet from a stranger though, got burned at a meet before. d!ckhead sold me a rv cam supposed to be a 383 magnum cam
Re: Would you buy a used race-cam ....?? [Re: dirtybee] #699740
05/17/10 12:01 AM
05/17/10 12:01 AM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
Hey db ...I might TAKE that RV cam !!
JUST CURIOUS ..... to the guys who HAVE bought a used cam ....what kind of money did you have to spend ...vs what it would have cost new ?
Re: Would you buy a used race-cam ....?? [Re: dirtybee] #699741
05/17/10 11:52 AM
05/17/10 11:52 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I bought 2 used cam and lifter sets from a guy years ago.He ran Mopars and I used one for 6 years and it still looks great.The other I never used.They pretty much looked new when I got them.I think I paid like 25 bucks each.Rocky
Chrysler Firepower
Re: Would you buy a used race-cam ....?? [Re: therocks] #699742
05/17/10 12:41 PM
05/17/10 12:41 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We change out used rollers a lot, never had any problems and they are less than half the cost of new, just check out the lobes and lifters when installing
Re: Would you buy a used race-cam ....?? [Re: MR_P_BODY] #699743
05/18/10 09:42 AM
05/18/10 09:42 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I couldn't agree more. Buying a used flat tappet cam is like buying used underwear.
Re: Would you buy a used race-cam ....?? [Re: BobR] #699744
05/18/10 10:10 AM
05/18/10 10:10 AM
AndyF Offline
AndyF  Offline
440Jim is running a flat tappet cam in his car that he bought used from me. Seems to be working just fine seeing how he is running almost 8 second times.
