'68/'69 A/C fan switch where can I find a new one? #698903
05/15/10 11:46 PM
05/15/10 11:46 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
I think that's what supposed to be in the spot in the attached photo but not sure what it looks like or where I can find one? Before I head to the local auto parts; am I wasting my time or is there a chance the local NAPA/Advance/Auto Zone/Pep Boys/etc might have one or get one for me??? Is it the same as an non-A/C fan resistor?
Thanks for any help.
MikeR
Re: '68/'69 A/C fan resistor where can I find a new one? [Re: A12] #698904
05/16/10 09:01 AM
05/16/10 09:01 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Mike,
That's the blower switch, resistor is on the heater/evap box.
I have one here from a non a/c control head. looks to be the same but can't tell for sure from the angle of the picture. Can you post a straight on from the top pic?
Re: '68/'69 A/C fan resistor where can I find a new one? [Re: rrunner] #698905
05/16/10 09:09 AM
05/16/10 09:09 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
The plug with three terminals is what plugs into the resistor on the box
Re: '68/'69 A/C fan resistor where can I find a new one? [Re: rrunner] #698906
05/16/10 09:43 AM
05/16/10 09:43 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Mike,
John, like this?
Re: '68/'69 A/C fan resistor where can I find a new one? [Re: A12] #698907
05/16/10 09:47 AM
05/16/10 09:47 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Any idea where I might be able to find a fan switch?
Re: '68/'69 A/C fan resistor where can I find a new one? [Re: A12] #698908
05/16/10 09:58 AM
05/16/10 09:58 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Mike,
John, like this?
Yes, Perfect. The pivot arm is different for sure but looks to be the same switch.
Let me get back with you in just a bit, I just remembered seeing a a/c switch in one of my stash boxes not long ago.
Re: '68/'69 A/C fan resistor where can I find a new one? [Re: rrunner] #698909
05/16/10 11:25 AM
05/16/10 11:25 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
OK I'm back. I think that's the fastest I've ever been able to find what I just saw not that long ago!
Here's a pic., a/c switch is different from the non a/c.
Mike I know you posted for new, but if you think you can use this switch, it's yours.
Re: '68/'69 A/C fan resistor where can I find a new one? [Re: A12] #698910
05/16/10 03:58 PM
05/16/10 03:58 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Mike,
This must be a common issue. I just pulled a used assy I have here and it looks just as bad as the one you have. so I'm no help
Re: '68/'69 A/C fan resistor where can I find a new one? [Re: rrunner] #698911
05/17/10 11:34 AM
05/17/10 11:34 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
John thanks I just sent you an email
I got real busy with a bunch of "honey-do" around the house projects and couldn't reply. I have the other end of that plug in the wiring harness but not that switch or pigtail anywhere to be found??? I need to check if it's available, you never know but I don't think I'm going to have any luck on that one.
Thanks again for the offer .
MikeR
Re: '68/'69 A/C fan resistor where can I find a new one? [Re: gtx6970] #698912
05/17/10 11:35 AM
05/17/10 11:35 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Mike,
Bill thanks for looking and it sure seems like a big issue to me too as most seem to being missing in action????
MikeR
