egt monitoring #698377
05/15/10 10:39 AM
05/15/10 10:39 AM
No. cal., sacramento usa
speedy383 Offline OP
Need to install egt sensors,thinking of Computech 4105.Any pros or cons? Also which pipes to install,which cylinders tend to run leaner? This is on methanol at 14.7 static Indy 3, 446 cu with Rons terminator. Also what is a safe range on alky ,I am thinking around 1100? Thanks.
Re: egt monitoring [Re: speedy383] #698378
05/15/10 05:57 PM
05/15/10 05:57 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i run an ETS data logger but Comp Cams bought the company & seemed to erased it off the market. i monitor all tubes & the temps range from 1060-1100*f. cylinders 3456 used to be dramaticly lean before my intake manifold got flowed along with my heads. i'm doing a new manifold so i'll be testing it's fuel distribution with the pyro's.
Re: egt monitoring [Re: rebel] #698379
05/15/11 05:51 PM
05/15/11 05:51 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Re: egt monitoring [Re: speedy383] #698380
05/15/11 06:25 PM
05/15/11 06:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I monitor all 8... they work great for balancing the
intake... I use a data logger called a Informer...
make sure all the probe ends are in the same spot...
I set mine exactly 1" from the flange surface
Re: egt monitoring [Re: MR_P_BODY] #698381
05/15/11 07:50 PM
05/15/11 07:50 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Last year I monitored only 2 cylinders. This year i have bought the Data Quest from logitech. I needed to know A LOT more info and this will give me what I need.
If your EGT's are all close you have a good balance, then turn to reading your plug burn. Last year my EGT's were around 1100-1150. But a pulling run is more like 15-23seconds.
Re: egt monitoring [Re: Diablo] #698382
05/15/11 08:58 PM
05/15/11 08:58 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
What system did you use last year DJ?
Re: egt monitoring [Re: mac56] #698383
05/15/11 09:03 PM
05/15/11 09:03 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Alot of the temp you see depends on the distance from the flange you are. I have 3 different sets of headers and I suggest the probes all be the same distance from the flange. Ideal would be 1 3/4 from the flange and alcy should be around 1150 to start and tune by the plug, as mentioned.
Re: egt monitoring [Re: mac56] #698384
05/15/11 10:04 PM
05/15/11 10:04 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
We used a computech System... it only reads 2 EGT's and RPM.... it was a good starting system but we now need to know how the fuel is effecting the EGT's through the run with our high speed pills and secondaries. The Data Quest will graph everything for us and plus we can add all kinds of neat things to it... I pretty much have my next 5 years of Xmas and B-day present planned out
U looking for a EGT reader?
Re: egt monitoring [Re: camastomcat] #698385
05/15/11 11:29 PM
05/15/11 11:29 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I have seen more than one expert say that ideally they should be in a spacer between the head and header. The closer to the head the better.I install mine as close as possible on the dyno.
Keith
Re: egt monitoring [Re: Dunnuck Racing] #698386
05/15/11 11:40 PM
05/15/11 11:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Keith
Thats the problem we ALL have a number we like to
put them in at... being that I worked in the exhaust
lab I tried to get everyone to put them in at a set
distance... which was 1" so we could talk apples
to apples... all the headers I built I put them in
at 1"... plus it was a easy number to remember
Re: egt monitoring [Re: MR_P_BODY] #698387
05/16/11 12:22 AM
05/16/11 12:22 AM
Northern Indiana
Northern Indiana
I agree,
I am trying to look as closely as I can at the temperatures seen in the combustion chamber,so the closer the better.A better way would be to look at the actual chamber temperatures but it is an expensive thing to accomplish.
In theory,as long as you check the plugs and get a reference egt number to go with them,then you have a number to aim for after making any changes.
Keith
Re: egt monitoring [Re: Dunnuck Racing] #698388
05/16/11 03:00 AM
05/16/11 03:00 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Has anyone experienced rich mixtures throwing off EGT values? by that I mean raw fuel igniting in the headers and giving off ultimately false readings?
Alan Jones
Re: egt monitoring [Re: LA360] #698389
05/16/11 10:31 AM
05/16/11 10:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes I've seen that... also really late timing...
they all will mess with the EGT reading... knowing
whats going on and also looking at the plugs goes
along with the readings
Re: egt monitoring [Re: MR_P_BODY] #698390
05/16/11 04:57 PM
05/16/11 04:57 PM
Yes I've seen that... also really late timing...they all will mess with the EGT reading... knowingwhats going on and also looking at the plugs goesalong with the readings
You can cool the EGT readings with to much fuel or to little Same thing on timing Piston aircraft motors use lean of peak with 50 to 75 F degrees of peak on turbocharged motors and 25 to 75 F degrres rich of peak on N/A motors That is at steady state RPMs adjusting the mixture controllers slowly to get the readings, some have single probe systems and some have multiple probe systems on the aircraft instrument monitoring equiptment
Re: egt monitoring [Re: Cab_Burge] #698391
05/16/11 06:44 PM
05/16/11 06:44 PM
SD USA
neonic Offline
neonic  Offline
SD USA
So why EGT monitoring? why not a wideband sensor. We run carb alcohol talking to APD they claim EGT's on alcohol are a waste of time.
Re: egt monitoring [Re: neonic] #698392
05/16/11 07:13 PM
05/16/11 07:13 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
What system do they recommend?
Re: egt monitoring [Re: neonic] #698393
05/16/11 07:40 PM
05/16/11 07:40 PM
Northern Indiana
Northern Indiana
For checking distribution problems,and remember that an oxygen sensor is usually mounted in the collector so you are getting an average reading from all the cylinders on that bank.I have seen some guys run oxygen sensors in each header tube to get accurate results
Keith
Re: egt monitoring [Re: Dunnuck Racing] #698394
05/16/11 08:14 PM
05/16/11 08:14 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Keith
EGT's are to find perfect balance for each cylinder. I know some that will change half jet sizes for each cylinder to find a balance.
Re: egt monitoring [Re: Dunnuck Racing] #698395
05/16/11 10:42 PM
05/16/11 10:42 PM
SD USA
neonic Offline
neonic  Offline
SD USA
They did not give us a recommendation on systems. Most data loggers have the ability to record LM1 readings. They said about the same as the formentioned to much of a possibility of burning fuel in the header tube. Many veribles can cause off readings.
Re: egt monitoring [Re: neonic] #698396
05/16/11 10:48 PM
05/16/11 10:48 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Speedy,
I already bought the computech EGT setup and I'm going to start with the back cylinders to get close then move to the other cylinders one at a time.
Might take more passes but I'll get it in the ballpark.
My combo is Injectorators on a tunnel ram so the manifold is not that much of a concern.
