Re: egt monitoring
[Re: speedy383]
#698380
05/15/11 06:25 PM
05/15/11 06:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I monitor all 8... they work great for balancing the intake... I use a data logger called a Informer... make sure all the probe ends are in the same spot... I set mine exactly 1" from the flange surface
Re: egt monitoring
[Re: Diablo]
#698382
05/15/11 08:58 PM
05/15/11 08:58 PM
Posts: 976 ontario canada
mac56
ontario canada
Last year I monitored only 2 cylinders. This year i have bought the Data Quest from logitech. I needed to know A LOT more info and this will give me what I need.
If your EGT's are all close you have a good balance, then turn to reading your plug burn. Last year my EGT's were around 1100-1150. But a pulling run is more like 15-23seconds.
What system did you use last year DJ?
Re: egt monitoring
[Re: mac56]
#698384
05/15/11 10:04 PM
05/15/11 10:04 PM
Posts: 1,106 Quebec, Canada
Diablo
Quebec, Canada
We used a computech System... it only reads 2 EGT's and RPM.... it was a good starting system but we now need to know how the fuel is effecting the EGT's through the run with our high speed pills and secondaries. The Data Quest will graph everything for us and plus we can add all kinds of neat things to it... I pretty much have my next 5 years of Xmas and B-day present planned out
U looking for a EGT reader?
Re: egt monitoring
[Re: camastomcat]
#698385
05/15/11 11:29 PM
05/15/11 11:29 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Alot of the temp you see depends on the distance from the flange you are. I have 3 different sets of headers and I suggest the probes all be the same distance from the flange. Ideal would be 1 3/4 from the flange and alcy should be around 1150 to start and tune by the plug, as mentioned.
I have seen more than one expert say that ideally they should be in a spacer between the head and header. The closer to the head the better.I install mine as close as possible on the dyno. Keith
Re: egt monitoring
[Re: Dunnuck Racing]
#698386
05/15/11 11:40 PM
05/15/11 11:40 PM
MR_P_BODY
Thats the problem we ALL have a number we like to put them in at... being that I worked in the exhaust lab I tried to get everyone to put them in at a set distance... which was 1" so we could talk apples to apples... all the headers I built I put them in at 1"... plus it was a easy number to remember
Re: egt monitoring
[Re: MR_P_BODY]
#698387
05/16/11 12:22 AM
05/16/11 12:22 AM
Dunnuck Racing
Northern Indiana
I agree, I am trying to look as closely as I can at the temperatures seen in the combustion chamber,so the closer the better.A better way would be to look at the actual chamber temperatures but it is an expensive thing to accomplish. In theory,as long as you check the plugs and get a reference egt number to go with them,then you have a number to aim for after making any changes. Keith
Re: egt monitoring
#698388
05/16/11 03:00 AM
05/16/11 03:00 AM
Posts: 6,138 Melbourne , Australia
LA360
Has anyone experienced rich mixtures throwing off EGT values? by that I mean raw fuel igniting in the headers and giving off ultimately false readings?
Alan Jones
Re: egt monitoring
[Re: LA360]
#698389
05/16/11 10:31 AM
05/16/11 10:31 AM
MR_P_BODY
Yes I've seen that... also really late timing... they all will mess with the EGT reading... knowing whats going on and also looking at the plugs goes along with the readings
Re: egt monitoring
[Re: neonic]
#698392
05/16/11 07:13 PM
05/16/11 07:13 PM
mac56
ontario canada
So why EGT monitoring? why not a wideband sensor. We run carb alcohol talking to APD they claim EGT's on alcohol are a waste of time.
What system do they recommend?
Re: egt monitoring
[Re: neonic]
#698393
05/16/11 07:40 PM
05/16/11 07:40 PM
Dunnuck Racing
Northern Indiana
For checking distribution problems,and remember that an oxygen sensor is usually mounted in the collector so you are getting an average reading from all the cylinders on that bank.I have seen some guys run oxygen sensors in each header tube to get accurate results Keith
Re: egt monitoring
#698394
05/16/11 08:14 PM
05/16/11 08:14 PM
Diablo
Quebec, Canada
EGT's are to find perfect balance for each cylinder. I know some that will change half jet sizes for each cylinder to find a balance.
Re: egt monitoring
[Re: neonic]
#698396
05/16/11 10:48 PM
05/16/11 10:48 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
Speedy, I already bought the computech EGT setup and I'm going to start with the back cylinders to get close then move to the other cylinders one at a time. Might take more passes but I'll get it in the ballpark. My combo is Injectorators on a tunnel ram so the manifold is not that much of a concern.
