4 bbl kickdown linkage and pivot on 904 #698231
05/15/10 12:46 AM
05/15/10 12:46 AM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
I was mocking up the 4 bbl kickdown linkage from a 70's Aspen on my '73 903 transmission(originally 2 bbl) and I notice the pivot bolt.rod that screws into the case seemed to short to slide through the pivot bracket for the 4 bbl linkage. Are the 4bbl pieces longer for that or do I just happen to have a fitting that's to short?
See pic if you are unsure what fitting I'm talking about
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: 4 bbl kickdown linkage and pivot on 904 [Re: MonGoo$e] #698232
05/15/10 05:59 AM
05/15/10 05:59 AM
5thAve Offline
5thAve  Offline
You mean the triangle looking part that the rod goes thru is too wide to fit right? The only difference for 4 barrel is the rod at the top. Maybe the size of the rod or the linkage part changed at some point.
Re: 4 bbl kickdown linkage and pivot on 904 [Re: 5thAve] #698233
05/15/10 10:28 AM
05/15/10 10:28 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
that bolt might be different between 904 and 727...
Re: 4 bbl kickdown linkage and pivot on 904 [Re: MonGoo$e] #698234
05/15/10 06:00 PM
05/15/10 06:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The pivot stud is the same for 727 and 904 in a given year but did change with the years; '70 and earlier is different from '71-on.
