A body SB TTI headers #697942
05/14/10 07:28 PM
05/14/10 07:28 PM
Streetsboro ,Ohio
72duster318 Offline OP
Streetsboro ,Ohio
Anyone have TTi headers on their A body with a small block and power steering? Im looking for any helpful tips you may have, the engine is on the K frame out of the car, so that should be a help, but just a quick test fitting doesnt look like they will fit. If you have a pic of the drvers side installed that would be helpful also. thanks guys
If you didn't build it yourself, it's not really yours - Tim "the toolman" Taylor
Re: A body SB TTI headers [Re: 72duster318] #697943
05/14/10 07:39 PM
05/14/10 07:39 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes they fit....But it's REALLY tight! You'll likely need to remove the torsion bars to install them.
Re: A body SB TTI headers [Re: ScottSmith_Harms] #697944
05/14/10 07:41 PM
05/14/10 07:41 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
There are W2 style headers (recent issue Mopar Performance W-2 cast iron heads) once installed they fit great with no major issues. This engine also used a compact mini starter which likely eased the install. I'm sure the regular TTI's with stock heads would clear fine as well, TTI's are known for a good fit.
Re: A body SB TTI headers [Re: 72duster318] #697945
05/15/10 01:39 AM
05/15/10 01:39 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
My 74 Duster has a 360, Power steering and a 4 speed. The TTI pipes fit great. Mine are the "step" headers that start at 1 5/8 and step to 1 3/4. They have a separate pipe for #7 that slips into place around the left T-bar. Nice design. I hated to spend the big money, but my patience is getting MUCH shorter as I get older.
Re: A body SB TTI headers [Re: Kern Dog] #697946
05/15/10 12:47 PM
05/15/10 12:47 PM
Streetsboro ,Ohio
Streetsboro ,Ohio
Thanks fr the replies and pictures. I played with them for about 3 hrs today, no way I can get them on the way the engine is sitting on the dolly. Looks like I will have to put the engine in the car, then fit the headers. Thanks again guys.
Re: A body SB TTI headers [Re: 72duster318] #697947
05/15/10 01:09 PM
05/15/10 01:09 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Mine hit the top of the P/S box, If you read the directions it will say the CL of the crank must sit I THINK 5 1/4" from the top of the k frame, my engine sat a bit lower and i had to shim it up. maybe Indian made motor mounts?
Re: A body SB TTI headers [Re: ademon] #697948
05/15/10 02:13 PM
05/15/10 02:13 PM
Locomotion Offline
Locomotion  Offline
Check the trans. mount also if there is any interference issues.
Re: A body SB TTI headers [Re: 72duster318] #697949
05/15/10 02:16 PM
05/15/10 02:16 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
i put mine on as per instructions with no issues,on my 73 340 duster
Re: A body SB TTI headers [Re: mcmopars] #697950
05/15/10 04:33 PM
05/15/10 04:33 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Hey Scott are engines are almost twins! Don't see the T-quad
Re: A body SB TTI headers [Re: ademon] #697951
05/15/10 04:34 PM
05/15/10 04:34 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
one more
Re: A body SB TTI headers [Re: ademon] #697952
05/15/10 05:12 PM
05/15/10 05:12 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That's not my engine it's my buddy's (Original 71 340 4 speed GY3 Demon) original numbers engine safely stashed. 422 stroker, Eagle crank & rods, ported iron W2 Heads & W2 intake, Holley 950, TTI's, (approx) 550 lift Roller Cam, etc. Made 520HP and 510TQ. Pretty stout street runner.
Re: A body SB TTI headers [Re: 72duster318] #697953
06/24/13 01:37 AM
06/24/13 01:37 AM
Daisyland USA
jnkgal Offline
jnkgal  Offline
Daisyland USA
been there done that we went through this
and you do start to wonder and.... do we actually need these on here lol they are an adventure to install on a dart
"A goal without a plan is just a wish."
Re: A body SB TTI headers [Re: ademon] #697954
06/24/13 02:28 AM
06/24/13 02:28 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I used mounts off a truck I think. They are thicker. That did the trick for me.
They fit fine with power steering for me. I was bleeding by the time I got the full size starter in thoughl
Re: A body SB TTI headers [Re: viperblue72] #697955
06/24/13 10:51 AM
06/24/13 10:51 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
My 67 Cuda has W2's with TTI 1 7/8" primaries. A real job to get the left side in after I installed PS. I thought heat would be an issue but was not on my trip from Carson City to Las Vegas
