highbeam problem #697358
05/13/10 09:03 PM
05/13/10 09:03 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
My A12 Bee's headlights go completely out after they've been on for a while, kick the switch to lows, and they come back on (lows that is) I know that means either the headlight switch, or the dimmer switch is getting hot, or has poor connections. Where is the best place to start?
Re: highbeam problem [Re: Kirby] #697359
05/13/10 09:32 PM
05/13/10 09:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Start with the headlight grounds on the radiator support. Then check the floor switch for corrosion. Then the only thing left is the headlight switch.
Re: highbeam problem [Re: stumpy] #697360
05/13/10 09:53 PM
05/13/10 09:53 PM
BDW Offline
BDW  Offline
Same problem here, please post what you find.
Re: highbeam problem [Re: Kirby] #697361
05/14/10 12:46 AM
05/14/10 12:46 AM
dimmer sw
Re: highbeam problem [Re: Kirby] #697362
05/14/10 06:55 AM
05/14/10 06:55 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
It wouldn't be the headlight switch, because that runs both high and low beams, so it wouldn't matter if you switch to lows when it goes out - they would be out also. I think (but I'm not positive) that the ground would be the same for both high and low beams. If so, then the same thing applies - it wouldn't matter if you switched to low beams, they would still be out.
I'm thinking you have a dimmer switch, or a bad connection, which would most likely be at the dimmer switch, or maybe at the bulkhead connector.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: highbeam problem [Re: Kirby] #697363
05/14/10 07:02 AM
05/14/10 07:02 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Headlight switch is very likely cause. (my 79 warlock did that after install of 4 hella bulbs. High beams on for a few minutes, went out, clicked back to low beams, came back on. New switch fixed it. I think there is breaker in switch.)
Re: highbeam problem [Re: Kirby] #697364
05/14/10 08:59 AM
05/14/10 08:59 AM
Houston, TX
Crunchy_Frog Offline
Houston, TX
I would check the dimmer switch first. Do a simple feel test. Turn the headlights on high and touch the DS (use back of fingers). If it gets hot, contacts have hi resistance. Power = current squared x resistance. Easiest thing to get to first.
Re: highbeam problem [Re: Kirby] #697365
05/14/10 10:31 AM
05/14/10 10:31 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Dimmer switch. Cheap, easy to change. Clean the socket contacts that it plugs into and put dielectric grease in there to protect it from corrosion. It sits in a bad place for moisture.
Craig
Re: highbeam problem [Re: denfireguy] #697366
05/14/10 03:05 PM
05/14/10 03:05 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
Re: highbeam problem [Re: Chilort] #697367
05/14/10 06:11 PM
05/14/10 06:11 PM
BDW Offline
BDW  Offline
Can you buy new dimmer switches?
Re: highbeam problem [Re: BDW] #697368
05/14/10 06:34 PM
05/14/10 06:34 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Yep...
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: highbeam problem [Re: HealthServices] #697369
05/14/10 06:57 PM
05/14/10 06:57 PM
BDW Offline
BDW  Offline
Thx, didn't know that.
Kind of surprised mine is flakey, I have my headlights on relays, so there's not really any current going through the switch or dimmer.
Re: highbeam problem [Re: BDW] #697370
05/14/10 07:07 PM
05/14/10 07:07 PM
So Cal
So Cal
Because the switch is under the carpet and moisture can get to it.
Re: highbeam problem [Re: HealthServices] #697371
05/14/10 10:14 PM
05/14/10 10:14 PM
Cookeville
Chilort Offline
Chilort  Offline
Cookeville
Mopar used the same dimmer switch for several decades. My '68 and '83 trucks use the same thing.
Re: highbeam problem [Re: Chilort] #697372
05/15/10 01:33 AM
05/15/10 01:33 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
1881938 Mopar number. Still available.
Re: highbeam problem [Re: superwrench] #697373
05/16/10 11:11 AM
05/16/10 11:11 AM
BDW Offline
BDW  Offline
Picked up a dimmer switch at AutoZone, $7.
Replacement is a little taller compared to the original, but it fixed my problem.
Thx!
