hemi in- but crooked? #697153
05/13/10 03:25 PM
05/13/10 03:25 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
I'm just about to fire the Cuda for the first time, and it was pointed out to me that my motor is not level. It's tipped down on the drivers side about 1/2 an inch. It is not helping the clearance of the t-bar and ex manifold either, and I'm wondering how bad it will make the shaker fit. Can I shim it somehow, or do I not have it quite in the right place on the K-member? doesn't seem that there would be any adjustment? Gotta have it done by june 5th- for Mopars at the Park.
Re: hemi in- but crooked? [Re: Kirby] #697154
05/13/10 03:32 PM
05/13/10 03:32 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
We'll We'll no need to go OFF half Cocked!!!!jk
Re: hemi in- but crooked? [Re: 340dart4spd ] #697155
05/13/10 03:56 PM
05/13/10 03:56 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Not uncommon, Schumacher in Wash. state sells shims.
Re: hemi in- but crooked? [Re: 469runner] #697156
05/13/10 03:59 PM
05/13/10 03:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried loosening up the mounts and jacking the motor up and reseting it?
Re: hemi in- but crooked? [Re: stumpy] #697157
05/13/10 04:21 PM
05/13/10 04:21 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah what he said. My 440 it sitting cockeyed in the car now. I'm going to jack it up loosen the MM bolts and get it in place then re-tighten them. I also have a solid on the drivers side so that could be the problem
Coming soon!!!!
Re: hemi in- but crooked? [Re: Kirby] #697158
05/13/10 04:24 PM
05/13/10 04:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What K frame are you using and what mounts , specifically if not factory whose parts do you have ?
Re: hemi in- but crooked? [Re: JohnRR] #697159
05/13/10 04:30 PM
05/13/10 04:30 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Factory mounts and k-member-
Re: hemi in- but crooked? [Re: Kirby] #697160
05/13/10 04:36 PM
05/13/10 04:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ok then loosen the rubber mount to K frame bolts , jack up under the oil pan and see if you can get it relocated .
Reason I ask is because according to Megaparts there are body specific engine brackets, and I wasn't sure if you were using conversion mounts of some sort .
Re: hemi in- but crooked? [Re: JohnRR] #697161
05/13/10 05:04 PM
05/13/10 05:04 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
hey John is there a difference in C-body and B-body MM brackets????
Coming soon!!!!
Re: hemi in- but crooked? [Re: Mr.Yuck] #697162
05/13/10 10:10 PM
05/13/10 10:10 PM
Ormond Beach, FL
71STROKERFISH Offline
Ormond Beach, FL
I had a vibration problem after removing my trans for a flex plate issue a couple years back. I ran this motor/trans for about 6yrs and installed it as one piece. After reinstalling the trans, separate from the motor, I noticed a vibration only at certain RPMS. I did the following....this procedure is in a factory troubleshooting guide someone on Moparts sent me when I was trouble shooting.....
After breaking in your engine........
1. Loosen motor mount bolts
2. Loosen Trans mount bolts
3. Fire off motor
4. Power brake motor a few times....more if required
5. Take measurements.
If the thing is straight and level, retorque all mount bolts, back car into street and put the heel to the steel!
-71STROKERFISH
-dc
SOUTHERNPLAINSMOPAARFEST.COM
2018 Jeep Trackhawk
1994 Jeep Grand Cherokee, 5.2 AWD-Daily grinder since 1997
1971 Barracuda, 414ci, 6bbl Fitech, 727
1970 Barracuda Convertible, 472 Ray Barton Hemi, 727
Re: hemi in- but crooked? [Re: Mr.Yuck] #697163
05/14/10 08:21 AM
05/14/10 08:21 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Wedge , depends on the year , but I'll say after 68 , or 69 ??? , no.
Re: hemi in- but crooked? [Re: JohnRR] #697164
05/14/10 12:53 PM
05/14/10 12:53 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
I'll try and move it around tonight, if that doesn't work, can I use some big washers to shim it up? Or
Re: hemi in- but crooked? [Re: JohnRR] #697165
05/14/10 02:31 PM
05/14/10 02:31 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
thanks it's a 70
