Alcohol additive #697044
05/13/10 11:10 AM
05/13/10 11:10 AM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
It was suggested to me that I use an oil additive in my fuel on my alcohol motor.
Can anyone elaberate on this for me, as to the por's and con's of using an additive and witch one would be best.
Thanx: JoWeTu_6
Re: Alcohol additive [Re: JoWeTu_6] #697045
05/13/10 12:07 PM
05/13/10 12:07 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Ok I did some moor checking looks like it's called top lube, do I get it where I buy the alky from or is it added by them when I buy it?
Re: Alcohol additive [Re: JoWeTu_6] #697046
05/13/10 12:24 PM
05/13/10 12:24 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I've used many different brands and feel the Klotz Uplon is by far the best. One bottle will treat 2 55gal drums. Keeps your pumps, fuel lines, etc. lubricated and somewhat protected from the alky. Less prone to corrode. I get mine from Comet kart sales
Some vendors sell alky with or without lube so you need to verify. I prefer without so I can add my own.
Re: Alcohol additive [Re: MegaDart] #697047
05/13/10 12:45 PM
05/13/10 12:45 PM
Arkansas
JoWeTu_6 Offline OP
JoWeTu_6  Offline OP
Arkansas
Hey thanx Wayne, I'm buying fuel today and needed some input I appreciate your's.
Re: Alcohol additive [Re: JoWeTu_6] #697048
05/13/10 03:12 PM
05/13/10 03:12 PM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
I really like Manhattan oil's power plus...I have used and sold it for years
Your valve guides and several other components will really thank you for using a lube..
And as mentioned above Klots is reall good also.
Re: Alcohol additive [Re: sc301v] #697049
05/13/10 03:50 PM
05/13/10 03:50 PM
north west LA
W
W2DODGE Offline
W2DODGE  Offline
W
north west LA
Nothing better than KLOTZ KL-100
Re: Alcohol additive [Re: MegaDart] #697050
05/13/10 04:49 PM
05/13/10 04:49 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
