Page 1 of 5 1 2 3 4 5
New Slant Six build #696604
05/12/10 09:40 PM
05/12/10 09:40 PM
Motor City
Shaker223 Offline OP
Motor City
I'm probably about a month away from seeing how this thing runs.
New Combo:
Wiseco forged pistons 7.7:1 comp ratio (1.0mm top ring , 1.5mm second ring, 3mm oil), Short block takes 11lbs to start rotating and 7lbs to maintain the spin.
K1 7.0" rods & ARP 2000 bolts (rods and pistons took almost 3lbs out over the stockers)
Hussy copper head gasket with block o-ringed
ARP head and main studs. Had a custom set of ARP 220,000 psi head studs made
Ported head / big valves (200cfm in/170 cfm ex....Stock was 120 In /90 ex)
Cam 114lsa, 227@50 .475" lift.
PTE 6262 DBB turbo, intercooled, with meth injection
600 Holley DP blow thru.
3.5" down pipe/exhaust to the axle and a 3" tail pipe
Old combo:
Stock engine 80k miles (7.6CR) with turbo bolted on and a lot of boost (29psi)
stock cam was .365" at the valve
Same turbo, Carb, header/exhaust...etc to be used in above.
Best pass on the old engine was: 11.77 @ 116mph @ 3500lbs race wt with 215/75/14 radials. Best MPH was just short of 118
Re: New Slant Six build [Re: Shaker223] #696605
05/12/10 09:45 PM
05/12/10 09:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The upgraded cam and increase in cyl head flow is going to make a phenomenal difference to that slant. You should at least get to the bottom 11's, but you're going to have to step it up in the traction department.
Re: New Slant Six build [Re: Shaker223] #696606
05/12/10 10:07 PM
05/12/10 10:07 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I'm really diggin that slant!!Keep us posted
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: New Slant Six build [Re: hemi-itis] #696607
05/12/10 10:13 PM
05/12/10 10:13 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I didn't know a stock Slant Six could tolerate 29 lbs of boost.
Is this engine going in the Dart Swinger behind it?
I'm excited to see what happens next.
Re: New Slant Six build [Re: In_The_Pink] #696608
05/12/10 10:38 PM
05/12/10 10:38 PM
Motor City
Motor City
The engine is going into the Swinger. I believe the stock engine had enough power to push the car into the low 11's given the mph. Traction was the problem. The best 60 was a 1.79 on the 215/75/14 radials. I'm hoping the new MT ET streets (255/60/15) allow me to leave on more than 3psi of boost and improve the overall ET. Given everything should in theory flow better. I may be able to do the same with less boost.
Vids of the car are on youtube....links are in my sig.
One of these days I'll take a pic of the failed piston.
Re: New Slant Six build [Re: Shaker223] #696609
05/13/10 08:58 PM
05/13/10 08:58 PM
Motor City
Motor City
Update
Re: New Slant Six build [Re: Shaker223] #696610
05/13/10 10:43 PM
05/13/10 10:43 PM
SRQ, FL
8valves Offline
8valves  Offline
SRQ, FL
If it doesn't go 9's I'll be dissapointed.
Nice stuff Tommy.
PS: you really need me to make you an intake.
Aaron M
Re: New Slant Six build [Re: 8valves] #696611
05/14/10 09:40 AM
05/14/10 09:40 AM
Motor City
Motor City
Nice stuff Tommy.
Not sure if it has 9's in it....if the car wwas lighter...maybe.
Should it be 16valves now?
Re: New Slant Six build [Re: Shaker223] #696612
05/14/10 10:56 AM
05/14/10 10:56 AM
Tolstoy, SD
turbo66valiant Offline
Tolstoy, SD
HHmmmm. Looks like I'm about to get beat. I think you'll hit the tens pretty easy. Don't forget to wax the Swinger for that extra tenth. Looks good Tom.
Later
Ryan
Turbo Slant 6 Valiant 10.74 @ 127.47 6.65 @ 107.80 http://www.youtube.com/user/turbo66valiant
Re: New Slant Six build [Re: Shaker223] #696613
05/14/10 11:43 AM
05/14/10 11:43 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
dude make sure..SURE your rear end can handle the extra hp/torque you are getting ready to unload. Ask me how I know... My 1st all out pass on my old 67 coronet ended in a completly destroyed 8.75. Granted it was 30+ years old and had seem hundreds of runs but the extra torque finished it. I'd back brace your rear before you try the stickies...
Re: New Slant Six build [Re: Mr.Yuck] #696614
05/14/10 12:43 PM
05/14/10 12:43 PM
GA
Boosted Offline
Boosted  Offline
GA
Now that is just to cool!!!
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: New Slant Six build [Re: Boosted] #696615
05/15/10 09:23 PM
05/15/10 09:23 PM
san diego
JonsGottaDusta Offline
san diego
I cannot wait to see what this car will run with the new combo. Its so rad.
Re: New Slant Six build [Re: JonsGottaDusta] #696616
05/15/10 10:06 PM
05/15/10 10:06 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
very cool build!!!
Re: New Slant Six build [Re: Mr.Yuck] #696617
05/16/10 12:02 AM
05/16/10 12:02 AM
Manitoba, Canada
Manitoba, Canada
But so long as you're running those dinky 215/75/14's I don't think you'll get enough traction to do some damage. Please tell us you're stepping up to some decent tires to show us what that slant can really do!
Re: New Slant Six build [Re: DaytonaTurbo] #696618
05/16/10 05:32 AM
05/16/10 05:32 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Love the car, want to do that some day
Re: New Slant Six build [Re: Shaker223] #696619
05/16/10 08:45 AM
05/16/10 08:45 AM
Motor City
Motor City
Yes, Tires have been stepped up!
Re: New Slant Six build [Re: Shaker223] #696620
05/16/10 08:10 PM
05/16/10 08:10 PM
MotorCity
RC91 Offline
RC91  Offline
MotorCity
That is just kewl. I can hardly wait to see new video's. It was impressive to see it running high 11's before, I'm hoping you'll see low 11's or high 10's with the new motor.
Re: New Slant Six build [Re: RC91] #696621
05/17/10 10:41 AM
05/17/10 10:41 AM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
Who did your port work? Looks like a lot of fun
Re: New Slant Six build [Re: wyldebill] #696622
05/17/10 01:42 PM
05/17/10 01:42 PM
Motor City
Motor City
A local Detroit guy who does a lot of turbo port work. Day job is at one of the major local shops. (lots of high end experience)
Re: New Slant Six build [Re: Shaker223] #696623
05/17/10 10:50 PM
05/17/10 10:50 PM
SRQ, FL
8valves Offline
8valves  Offline
SRQ, FL
Nice stuff Tommy.
I've still got an 8V car, and the new one has 8 per bank!
Then the other motor has 10 per bank, not sure what my excuse will be then!
Aaron M
