ARP main stud torque specs? #696512
05/12/10 08:38 PM
05/12/10 08:38 PM
Lexington,VA
68gtxsurvivor Offline OP
Lexington,VA
Anybody know the torque specs for ARP main studs in a 440
Re: ARP main stud torque specs? [Re: 68gtxsurvivor] #696513
05/12/10 09:06 PM
05/12/10 09:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I think it`s a 100ft.lbs..........
Re: ARP main stud torque specs? [Re: Thumperdart] #696514
05/12/10 10:29 PM
05/12/10 10:29 PM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline
My spec sheet shows 82#. Thats an original from A.R.P. See ya, Ken
Re: ARP main stud torque specs? [Re: 1974 474 Duster] #696515
05/12/10 10:38 PM
05/12/10 10:38 PM
wentzville mo
1974PW Offline
1974PW  Offline
wentzville mo
just put mine in today and alined honed it. 1/2 stud is 110 ft pounds with the ARP lube.
Re: ARP main stud torque specs? *DELETED* [Re: 68gtxsurvivor] #696516
05/13/10 09:59 AM
05/13/10 09:59 AM
Arkansas
JoWeTu_6 Offline
JoWeTu_6  Offline
Arkansas
Post deleted by JoWeTu_6
Re: ARP main stud torque specs? [Re: JoWeTu_6] #696517
05/13/10 10:11 AM
05/13/10 10:11 AM
tboomer Offline
tboomer  Offline
Re: ARP main stud torque specs? [Re: tboomer] #696518
05/13/10 10:28 AM
05/13/10 10:28 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
My 7/16 studs get 70 ft/lbs and the 1/2 get 90 ft/lbs with moly lube
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: ARP main stud torque specs? [Re: 68gtxsurvivor] #696519
05/13/10 11:53 AM
05/13/10 11:53 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I always torque mine to 100 lb really stops cap walk and ARP states the 90 lb is only 75% of what the bolts will take
Re: ARP main stud torque specs? [Re: Dodgem] #696520
05/13/10 01:00 PM
05/13/10 01:00 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
My machine shop said 100 ft lbs with the arp lube and something different with just oil. we used the arp lube at 100 lbs.
67' charger 499 RB 10.57 at 127
Re: ARP main stud torque specs? [Re: dragram440] #696521
05/13/10 01:09 PM
05/13/10 01:09 PM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
100 lbs with arp lube.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: ARP main stud torque specs? [Re: moparmxz] #696522
05/13/10 10:01 PM
05/13/10 10:01 PM
wentzville mo
1974PW Offline
1974PW  Offline
wentzville mo
i wonder if arp changed something recently because i just got mine 2 days ago and the paper says 110ft pounds witht the lube they give you... i will see if i can get to a scanner and show you guys
Re: ARP main stud torque specs? [Re: 1974PW] #696523
05/13/10 11:04 PM
05/13/10 11:04 PM
lake charles, la
sc4400 Offline
sc4400  Offline
lake charles, la
I got my first set at least 15 years ago, the specs were 110 1-4 and 100#5
RIP
Re: ARP main stud torque specs? [Re: 68gtxsurvivor] #696524
05/14/10 12:13 AM
05/14/10 12:13 AM
Maple Ridge, BC, Canada
N
NitroFixx Offline
NitroFixx  Offline
N
Finger tight
Seriously my sheet showed
90 ft lbs with ARP moly lube
130 ft lbs with 30w motor oil
