Dip Stick Tube Leak - 727 #696419
05/12/10 06:59 PM
05/12/10 06:59 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
I am trying to beat a leaky dip stick tube. I got a new o ring seal and I am getting ready to put it back together. Do you guys put a little RTV or any sealant around the O Ring or at the base of the transmission or should I just leave it as is. Thanks!!!!
Re: Dip Stick Tube Leak - 727 [Re: faud88] #696420
05/12/10 07:09 PM
05/12/10 07:09 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
make sure you push it in far enough. Had a leaky dipstick once. swore I had it seated, my old man came along and pushed it in some more, problem solved
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Dip Stick Tube Leak - 727 [Re: faud88] #696421
05/12/10 07:09 PM
05/12/10 07:09 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
Ive always put some ATV on dipsticks.....it just makes it alittle easier especially when dealing with older/cruster tube that have been around awhile...
Also let it sit overnite....
Re: Dip Stick Tube Leak - 727 [Re: Hemiruss] #696422
05/12/10 11:22 PM
05/12/10 11:22 PM
Tucson, AZ
Ramrod39 Online work
My New Title
Ramrod39  Online Work
My New Title
Tucson, AZ
Definately. Put some RTV on the O ring. Don't be shy about it either. A bead of RTV on the outer case will not be seen.
Re: Dip Stick Tube Leak - 727 [Re: kilroy] #696423
05/12/10 11:49 PM
05/12/10 11:49 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Also that it is mounted
Re: Dip Stick Tube Leak - 727 [Re: faud88] #696424
05/13/10 01:35 AM
05/13/10 01:35 AM
before using the RTV follow std RTV procedure of cleaning the hole/tube (drop the pan if need be to clean it right) w brake kleen then letting the RTV set up overnight
Re: Dip Stick Tube Leak - 727 [Re: RapidRobert] #696425
05/13/10 08:16 AM
05/13/10 08:16 AM
scratchnfotraction Offline
use the mopar blackATF/RTV and let cure over night
works every time,that stuff will hold up well to the tranz fluid
