Page 1 of 3 1 2 3
KB pistons BREAK IN HALF??? #696205
05/12/10 03:48 PM
05/12/10 03:48 PM
Tulsa, Oklahoma
Charger_440 Offline OP
Tulsa, Oklahoma
ive been doing some research and had bought some KB 107's to use in my 360 build, but have had 2 builders refuse to use them, saying they have a tendancy to break...crack right down the middle. has anyone had any experience with this happening? these are VERY well known engine builders, not just local guys
In a conversation with a Wyoming State Patrolman... "A 318 ??!!! But I clocked you at 142 mph!!!"
Re: KB pistons BREAK IN HALF??? [Re: Charger_440] #696206
05/12/10 03:53 PM
05/12/10 03:53 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
I don't use them very often, but they are a good piston. The problem is, people don't read the ring gapping instructions. Since the top ring land is high, you MUST wide gap the top ring, or you will break that sucker!
Re: KB pistons BREAK IN HALF??? [Re: Charger_440] #696207
05/12/10 03:54 PM
05/12/10 03:54 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Have a set of kb107 in 360 with thousands of miles of on them...still in one piece.
maybe the engine builder did not read the instructions about setting the ring gap for hyper pistons...and probably not since he is well known.
Tony
70 AARCuda Vitamin C
Re: KB pistons BREAK IN HALF??? [Re: todd440] #696208
05/12/10 03:56 PM
05/12/10 03:56 PM
Indy
moparman89 Offline
moparman89  Offline
Indy
If the builder reads the instructions that comes with the pistons and FOLLOWS them, they wont break. Half the builders throw them away and do their own thing. The engineers who design these things are not stupid.
Re: KB pistons BREAK IN HALF??? [Re: moparman89] #696209
05/12/10 03:59 PM
05/12/10 03:59 PM
Tulsa, Oklahoma
Tulsa, Oklahoma
one was saying that ever since the production went to mexico the quality sucks. i hope he isnt right bcse i have $ invested in these, both of these guys reccommend SRP pistons. any thoughts on that?
Re: KB pistons BREAK IN HALF??? [Re: Charger_440] #696210
05/12/10 04:01 PM
05/12/10 04:01 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
In 2.2 turbo applications they are avoided like the plague.
They are very brittle pistons that are cheap to make.
Re: KB pistons BREAK IN HALF??? [Re: Charger_440] #696211
05/12/10 04:02 PM
05/12/10 04:02 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
and what be the difference if they were made in southern california????
Tony
Re: KB pistons BREAK IN HALF??? [Re: gdonovan] #696212
05/12/10 04:11 PM
05/12/10 04:11 PM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
In a turbo application you're not supposed to use a hypereutectic piston anyway regardless of who manufactures it, and I was told that by representatives from two different piston companies. As for the KB107s, I've used hundreds and hundreds over the years with resounding success, as well as many other KB hypereutectic pistons. Like the others said, follow the directions for increasing the gap on the top ring and you're good to go.
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: KB pistons BREAK IN HALF??? [Re: maundmotorworks] #696213
05/12/10 04:17 PM
05/12/10 04:17 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Which doesn't change the fact there are companies making them for factory turbo applications.
Turbo or supercharged or nitrous will reduce hyperutectic pistons to junk quick.
Factory cast are better or forged, I have put 30 psi of boost to factory chrylser pistons and they live.
Re: KB pistons BREAK IN HALF??? [Re: gdonovan] #696214
05/12/10 04:24 PM
05/12/10 04:24 PM
Stealth poster
Stealth poster
Yeah, I know they still make them for turbo applications anyway despite that they wouldn't hold up well. Forged is indeed the way to go since they hold up in pretty much any application. And I think you're right on another account--a cast piston is a tough S.O.B! Look at what the drag guys used to do with cast pistons before the forged stuff came available, and that was even severe punishment for forged pistons.
Re: KB pistons BREAK IN HALF??? [Re: maundmotorworks] #696215
05/12/10 04:37 PM
05/12/10 04:37 PM
Tulsa, Oklahoma
Tulsa, Oklahoma
my build is not a boosted build. its a LA 360, stock build except cam and pistons. adn ported heads. so, anybody wth an NA build that has actually had this problem? both of these guys work predominantly with race engines, so maybe a street engine they'd be ok? i hadnt heard ths before now, but for 2 ppl in 2 weeks to say it...scared me.
Re: KB pistons BREAK IN HALF??? [Re: Charger_440] #696216
05/12/10 04:55 PM
05/12/10 04:55 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Have seen many KB pistons and about the only ones I have seen that break are not installed properly.FOLLOW the directions. Mine have seen many seasons.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: KB pistons BREAK IN HALF??? [Re: Charger_440] #696217
05/12/10 04:56 PM
05/12/10 04:56 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Got em in the BB. No problems after 6 years of misuse. My builder is well known.
Re: KB pistons BREAK IN HALF??? [Re: Charger_440] #696218
05/12/10 05:02 PM
05/12/10 05:02 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..even though most on Moparts recomend these pistons,i also know builders that refuse to use them.
Re: KB pistons BREAK IN HALF??? [Re: Charger_440] #696219
05/12/10 05:44 PM
05/12/10 05:44 PM
douglasville,ga
ramrod Offline
ramrod  Offline
douglasville,ga
I run KB hypers in my drag car. 360 with cast crank and stock connecting rods. I shift at 7K and the engine has seen 8K a time or two. MANY HUNDREDS of passes with no problem. Pay attention to the top ring gap and you will be fine.
"That Plymouth had a Hemi with a Torqueflite." -Driver
Re: KB pistons BREAK IN HALF??? [Re: ramrod] #696220
05/12/10 06:21 PM
05/12/10 06:21 PM
Tulsa, Oklahoma
Tulsa, Oklahoma
thanks for easin my mind fellas
Re: KB pistons BREAK IN HALF??? [Re: todd440] #696221
05/12/10 06:38 PM
05/12/10 06:38 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
just how are they breaking? are they splitting down the middle? or halfway up? or if its splitting down the the middle the rings are not gonna cause a split it would more then likely from having prosity problem(something your not gonna see unless you x ray it(and im sure you guys didnt lol) iv made over 100,000 pistons working for briggs (yes there cast but not hand poured) and have seen my share of problems installing the rings wrong may cause some problems but spliting a piston prob wont be one of them
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: KB pistons BREAK IN HALF??? [Re: toplescuda] #696222
05/12/10 08:21 PM
05/12/10 08:21 PM
Tulsa, Oklahoma
Tulsa, Oklahoma
any suggestion on rings to use? he said hastings rings are like "a bore in a box" he tells me to use speedpro seal power moly rings. any input there? i want something with a long life to it. the originals in my 318 lasted 264k mi before i rebuilt it, i want something thats gonna be there for the long haul, not smoke after 65k mi.
thanks guys
Re: KB pistons BREAK IN HALF??? [Re: Charger_440] #696223
05/12/10 08:37 PM
05/12/10 08:37 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
id like to see a pic of the piston the o p said was cracked right down the middle
1971 charger
383man [Re: toplescuda] #696224
05/12/10 10:35 PM
05/12/10 10:35 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have KB pistons running in 3 engines and all have worked fine. My 63 and my sons Dart have had them for years with many street miles and a few trips to the track every year. Also have a set in my buddies car. All are bigblocks. Mine is a 440 my sons is a 400 and my buddies is a 383. And as was said you HAVE TO SET THE TOP RING GAP RIGHT !!! Ron
Page 1 of 3 1 2 3
