KB pistons BREAK IN HALF???
#696205
05/12/10 03:48 PM
05/12/10 03:48 PM
Posts: 715 Tulsa, Oklahoma
Charger_440
Tulsa, Oklahoma
ive been doing some research and had bought some KB 107's to use in my 360 build, but have had 2 builders refuse to use them, saying they have a tendancy to break...crack right down the middle. has anyone had any experience with this happening? these are VERY well known engine builders, not just local guys
In a conversation with a Wyoming State Patrolman... "A 318 ??!!! But I clocked you at 142 mph!!!"
Re: KB pistons BREAK IN HALF???
[Re: Charger_440]
#696207
05/12/10 03:54 PM
05/12/10 03:54 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Have a set of kb107 in 360 with thousands of miles of on them...still in one piece.
maybe the engine builder did not read the instructions about setting the ring gap for hyper pistons...and probably not since he is well known.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: moparman89]
#696209
05/12/10 03:59 PM
05/12/10 03:59 PM
Charger_440
Tulsa, Oklahoma
one was saying that ever since the production went to mexico the quality sucks. i hope he isnt right bcse i have $ invested in these, both of these guys reccommend SRP pistons. any thoughts on that?
[Re: Charger_440]
#696210
05/12/10 04:01 PM
05/12/10 04:01 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
In 2.2 turbo applications they are avoided like the plague.
They are very brittle pistons that are cheap to make.
[Re: Charger_440]
#696211
05/12/10 04:02 PM
05/12/10 04:02 PM
70AARcuda
las vegas
and what be the difference if they were made in southern california????
Tony
[Re: gdonovan]
#696212
05/12/10 04:11 PM
05/12/10 04:11 PM
Posts: 1,209 Fredericktown, PA 15333
maundmotorworks
Stealth poster
Stealth poster
In a turbo application you're not supposed to use a hypereutectic piston anyway regardless of who manufactures it, and I was told that by representatives from two different piston companies. As for the KB107s, I've used hundreds and hundreds over the years with resounding success, as well as many other KB hypereutectic pistons. Like the others said, follow the directions for increasing the gap on the top ring and you're good to go.
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
[Re: maundmotorworks]
#696213
05/12/10 04:17 PM
05/12/10 04:17 PM
gdonovan
Oakdale CT
Which doesn't change the fact there are companies making them for factory turbo applications.
Turbo or supercharged or nitrous will reduce hyperutectic pistons to junk quick.
Factory cast are better or forged, I have put 30 psi of boost to factory chrylser pistons and they live.
#696215
05/12/10 04:37 PM
05/12/10 04:37 PM
Charger_440
Tulsa, Oklahoma
my build is not a boosted build. its a LA 360, stock build except cam and pistons. adn ported heads. so, anybody wth an NA build that has actually had this problem? both of these guys work predominantly with race engines, so maybe a street engine they'd be ok? i hadnt heard ths before now, but for 2 ppl in 2 weeks to say it...scared me.
[Re: Charger_440]
#696216
05/12/10 04:55 PM
05/12/10 04:55 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Have seen many KB pistons and about the only ones I have seen that break are not installed properly.FOLLOW the directions. Mine have seen many seasons.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: Charger_440]
#696219
05/12/10 05:44 PM
05/12/10 05:44 PM
Posts: 199 douglasville,ga
ramrod
douglasville,ga
I run KB hypers in my drag car. 360 with cast crank and stock connecting rods. I shift at 7K and the engine has seen 8K a time or two. MANY HUNDREDS of passes with no problem. Pay attention to the top ring gap and you will be fine.
"That Plymouth had a Hemi with a Torqueflite."
-Driver
[Re: ramrod]
#696220
05/12/10 06:21 PM
05/12/10 06:21 PM
Charger_440
Tulsa, Oklahoma
thanks for easin my mind fellas
[Re: toplescuda]
#696222
05/12/10 08:21 PM
05/12/10 08:21 PM
Charger_440
Tulsa, Oklahoma
any suggestion on rings to use? he said hastings rings are like "a bore in a box" he tells me to use speedpro seal power moly rings. any input there? i want something with a long life to it. the originals in my 318 lasted 264k mi before i rebuilt it, i want something thats gonna be there for the long haul, not smoke after 65k mi.
thanks guys
