K Frame Bolts "73" B Body #695695
05/12/10 10:36 AM
05/12/10 10:36 AM
Fort Myers, Florida
rserio Offline OP
rserio  Offline OP
Fort Myers, Florida
I've searched the vendors here but still couldn't find the (4) k frame bolts for my 73 road runner. Everything up to the 72 is out there but the 73 & up seems kind of scarce. Any help in locating these bolts is GREATLY appreciated. I want to support the vendors here to keep the site rockin'.
Thanks,
Ron
73 roadrunner E55 D21 A36
Re: K Frame Bolts "73" B Body [Re: rserio] #695696
05/12/10 10:47 AM
05/12/10 10:47 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I don't think anyone reproduces those bolts because they don't come out often enough to be the kind of thing you typically lose. If you want I can measure mine so you can replace it with a regular grade 8 bolt. I have the k frame out anyway.
Re: K Frame Bolts "73" B Body [Re: DaytonaTurbo] #695697
05/12/10 10:53 AM
05/12/10 10:53 AM
Fort Myers, Florida
rserio Offline OP
rserio  Offline OP
Fort Myers, Florida
That would be great. Thanks for the reply. (73 & up get no love)
Re: K Frame Bolts "73" B Body [Re: DaytonaTurbo] #695698
05/12/10 11:01 AM
05/12/10 11:01 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Don't those bolts have a locating shoulder on them? Not sure a grade 8 bolt will work.
Re: K Frame Bolts "73" B Body [Re: dmerc] #695699
05/12/10 11:45 AM
05/12/10 11:45 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Don`t think they are being reproduced. I found a couple NOS bolts a while back but they are hard to find. The problem with any store bought bolt is the thread length is too short.
Re: K Frame Bolts "73" B Body [Re: mopars4ever] #695700
05/12/10 08:04 PM
05/12/10 08:04 PM
Atlantic Mine MI
YooperLon Offline
YooperLon  Offline
Atlantic Mine MI
What a small world. I have my k-frame out,too. The bolts in my 73 Sat measure 5/8" by 5" long measured from under the head. My bolts are not shouldered. And have 3 lines on the head of the bolt, indicating that they are Gr. 5. I used a wire wheel on a bench grinder to remove the caked on rust/dirt (took awhile). Now, I can thread on a nut using just my hands all the way up. Hope this helps.
73 Satellite 440-727-8.75
97 Ram Sport 4X4 5.2Magnum
Re: K Frame Bolts "73" B Body [Re: dmerc] #695701
05/12/10 08:23 PM
05/12/10 08:23 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
I believe they have a special washer and a tapered self-tapping type end.
I should have at least one clean set of 4 available. If you can wait until the 23rd I can check then.
Re: K Frame Bolts "73" B Body [Re: rserio] #695702
05/12/10 09:40 PM
05/12/10 09:40 PM
NW Arkansas
challengersteve Offline
NW Arkansas
Hello Ron, I have a set on a parts car in our salvage. I have sent you an email.
Thanks, Steve.
Re: K Frame Bolts "73" B Body [Re: challengersteve] #695703
05/13/10 10:44 PM
05/13/10 10:44 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The bolts are'nt a standard style store-bought piece...There are plenty of the isolated k frame cars out there to find a good set...Cordoba, magnum, charger, etc... Every boneyard around here has it's choice of these cars...
Re: K Frame Bolts "73" B Body [Re: screamindriver] #695704
05/14/10 07:42 AM
05/14/10 07:42 AM
Fort Myers, Florida
rserio Offline OP
rserio  Offline OP
Fort Myers, Florida
Thanks for the replies. Steve @ musclecars hooked me up with a set.
Ron
