Running Mickey Thompsons on the Street? #695683
05/12/10 09:30 AM
05/12/10 09:30 AM
Berlin, Germany
Flo Offline OP
Flo  Offline OP
Berlin, Germany
Anyone running
Mickey Thompson Sportsman S/R Tires
on the street? Hhow do they perform around corners, how do they work in the wet?
Need sticky 15" tires and there is not much out there.
Greets
Flo
1967 Fury III 4door HT tiny 318, late model roller block, bored and stroked to 344
Re: Running Mickey Thompsons on the Street? [Re: Flo] #695684
05/12/10 09:39 AM
05/12/10 09:39 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i just installed some Nitto drag radials on my demon, seem to hook very nice, only about 20 miles so far $350 installed and ballanced at discount tires 275/60 15's
Re: Running Mickey Thompsons on the Street? [Re: Flo] #695685
05/12/10 09:58 AM
05/12/10 09:58 AM
Berlin, Germany
Flo Offline OP
Flo  Offline OP
Berlin, Germany
Problem is I do not dragrace. I want to be able to go around turns and still drive in the rain. The Nittos are the NT555R I guess. Do they work in the wet and around turns?
Greets
Flo
Re: Running Mickey Thompsons on the Street? [Re: Flo] #695686
05/12/10 10:20 AM
05/12/10 10:20 AM
scratchnfotraction Offline
I run 29x15x15 M/T sportsman SR radials on 12" rims on my lowerd/tubbed 85 stepside truck
26x8x15 on 7" rims in front
work way better in the rain than the sportsman/sportsman pro tires
they have not hydro planed in the wet yet,unlike the sportsman pros I had last..about 35-40 mph in the wet with them and hydro bad
the SR radial in the wet are up to 55-65 mph and have not hydro yet,I feel very comfortable in the rain at some speed with them
they have been on for a little over a yr and are wearing very little on the back...front end is wearing the front cause of bad alinement
I run about 25lbs of air in the back and have no traction problems..my 318 is not gonna break them loose for sure...but i can drop the air some to get a good bite on the wet road
my pros hooked good at 12-16 lbs of air but would get on the top end at speed
the SRs are a better rubber compound just for the street and tubbed/wide rims and wear well with cornering...so they said
my pros only lasted 14 mounths with daily driveing and wore in the middle with 20 lbs of air..which is max on the tire
for longjevity and wet weather..well worth the $$$
Re: Running Mickey Thompsons on the Street? [Re: scratchnfotraction] #695687
05/12/10 10:55 AM
05/12/10 10:55 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
side walls look fine, and handle fine around corners, I don't drive in the rain but the reveiws seem to say they are good in rain.
Re: Running Mickey Thompsons on the Street? [Re: ademon] #695688
05/12/10 07:37 PM
05/12/10 07:37 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
I've had on my 325 MT DR's on for nearly 5 years. Same tires. Rain sucks. I don't do many burn outs. Been down the track maybe...10 or 15 times. They are still good to go for this year..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Running Mickey Thompsons on the Street? [Re: sunroofgtx] #695689
05/13/10 03:16 PM
05/13/10 03:16 PM
Berlin, Germany
Flo Offline OP
Flo  Offline OP
Berlin, Germany
@sunroofgtx:
are you sure we are talking the same tire? Yours look like the "ET Street Radial". That one is listed as a race tire opposite to the Sportsmans I am asking for which are listed as street tires. They highlight the flamed thread for improved wet traction
Greets
flo
Re: Running Mickey Thompsons on the Street? [Re: Flo] #695690
05/13/10 05:02 PM
05/13/10 05:02 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Sorry.. I suck at reading.. My bad..
Re: Running Mickey Thompsons on the Street? [Re: Flo] #695691
05/13/10 05:22 PM
05/13/10 05:22 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I ran them for a few months but not a lot of mile and my truck only sees dry weather so I can't say how they handle in the rain. But, for normal driving, they seemed fine.
Re: Running Mickey Thompsons on the Street? [Re: Flo] #695692
05/14/10 01:53 AM
05/14/10 01:53 AM
I have a customer who is running the 29x18x15 (I think that is the correct size) MT SR and they are not sticky at the track or on the street according to him.He had another set of MT Sportsman Pros that are bigger that where not sticky either He just bought another set of rims(15x150 and tires, MT drag radials 12.25x31.25x15R for the track Maybe he will chime in on how the car drives on the street and the wet, if he has driven it in the wet
Re: Running Mickey Thompsons on the Street? [Re: Cab_Burge] #695693
05/15/10 03:08 PM
05/15/10 03:08 PM
Joplin, Missouri
Mac's Hemi 64 Offline
Joplin, Missouri
I have not driven in the rain with them. But they drive excellent on the street. The agressive tread pattern they have would be great in the wet. Not worth a hoot at the track though. For just street driving I think you would like them.
