Re: World Products block starter clearance issues
[Re: nosboy]
#695644
05/12/10 07:52 AM
05/12/10 07:52 AM
Posts: 2,826 NY usa
540challenger
NY usa
I have a World products 4.500 bore siamese wedge engine and I am trying to bolt up the starter BUT there is a clearance issue with the B positive terminal up against the block. I have one of those mini starters and I was wondering if there was a relocation kit OR another starter that would bolt up that was different??? PLEASE HELP....Thanks,, Gary Oles nosboy
Sorry not try to be a smart A## but did you remove the plastic extendsion off the terminals. I have also seen some guys grind the post down a little or RobbMc "clockable" starter might be another route to go.
[Re: nosboy]
#695645
05/12/10 07:57 AM
05/12/10 07:57 AM
Posts: 627 IN
BIG BEAR
IN
We use a Ford style solenoid mounted in a remote location, such as on our running test engine/stand, that allows enough clearance away from the casting (it should work on your block too) - Koleno Performance
[Re: BIG BEAR]
#695646
05/12/10 08:16 AM
05/12/10 08:16 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
i had to remove the terminal extention and grind the terminal down and use thinner(home made) nuts.
[Re: BIG BEAR]
#695648
05/12/10 09:22 AM
05/12/10 09:22 AM
Posts: 16,928 NC
440Jim
NC
So, do you remove the starter mounted solenoid? What needs to be done, any pics?
[Re: nosboy]
#695649
05/12/10 09:24 AM
05/12/10 09:24 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I cut the terminal down and all is good.
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#695650
05/12/10 10:03 AM
05/12/10 10:03 AM
Posts: 6,295 U.S.
moparniac
U.S.
I went out and checked my world aluminum block and it seems to be touching! meaning i couldnt tighten the nut down but it will fit if i put the cable on first before mounting the starter ( A body ) but ill anyway ...
Mopar Performance
[Re: 440Jim]
#695652
05/12/10 12:23 PM
05/12/10 12:23 PM
Posts: 627 IN
BIG BEAR
IN
I'll try to post some pics of our set up
[Re: BIG BEAR]
#695654
05/12/10 12:29 PM
05/12/10 12:29 PM
Posts: 627 IN
BIG BEAR
IN
[Re: BIG BEAR]
#695656
05/12/10 12:41 PM
05/12/10 12:41 PM
Posts: 627 IN
BIG BEAR
IN
[Re: Moparnut426]
#695657
05/12/10 12:48 PM
05/12/10 12:48 PM
Posts: 1,288 Oregon
sg66mopar
There was a similar post on here about 2 months ago. I gave the guy the bracket off of a dakota starter. They have a brass strap that is bent out and down from the solonoid and puts the starter power stud pointing to the front of the car. then ya cut off the stud at the top, and you should clear. Ill check to see if I aquired any more parts since the last time I gave them away. I have 3 more cores since I gave him that part.
Kasey
Kasey, that was me you gave the strap to and it helped a lot. I have it on my mini starter right now and I'm gonna get some pics posted by this afternoon.
I bought the Powermaster starter and the mini is just going to be a spare now.
[Re: nosboy]
#695659
05/12/10 05:16 PM
05/12/10 05:16 PM
Posts: 627 IN
BIG BEAR
IN
