World Products block starter clearance issues #695643
05/12/10 07:46 AM
05/12/10 07:46 AM
Chicago,Illinois
N
nosboy Offline OP
nosboy  Offline OP
N
Chicago,Illinois
I have a World products 4.500 bore siamese wedge engine and I am trying to bolt up the starter BUT there is a clearance issue with the B positive terminal up against the block. I have one of those mini starters and I was wondering if there was a relocation kit OR another starter that would bolt up that was different??? PLEASE HELP....Thanks,, Gary Oles nosboy
Re: World Products block starter clearance issues [Re: nosboy] #695644
05/12/10 07:52 AM
05/12/10 07:52 AM
NY usa
540challenger Offline
NY usa
Sorry not try to be a smart A## but did you remove the plastic extendsion off the terminals. I have also seen some guys grind the post down a little or RobbMc "clockable" starter might be another route to go.
Re: World Products block starter clearance issues [Re: nosboy] #695645
05/12/10 07:57 AM
05/12/10 07:57 AM
IN
BIG BEAR Offline
BIG BEAR  Offline
IN
We use a Ford style solenoid mounted in a remote location, such as on our running test engine/stand, that allows enough clearance away from the casting (it should work on your block too) - Koleno Performance
Re: World Products block starter clearance issues [Re: BIG BEAR] #695646
05/12/10 08:16 AM
05/12/10 08:16 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i had to remove the terminal extention and grind the terminal down and use thinner(home made) nuts.
Re: World Products block starter clearance issues [Re: nosboy] #695647
05/12/10 09:19 AM
05/12/10 09:19 AM
NC
440Jim Offline
440Jim  Offline
NC
Is this the aluminum or the cast iron World block?
Re: World Products block starter clearance issues [Re: BIG BEAR] #695648
05/12/10 09:22 AM
05/12/10 09:22 AM
NC
440Jim Offline
440Jim  Offline
NC
So, do you remove the starter mounted solenoid? What needs to be done, any pics?
Re: World Products block starter clearance issues [Re: nosboy] #695649
05/12/10 09:24 AM
05/12/10 09:24 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I cut the terminal down and all is good.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: World Products block starter clearance issues [Re: Hemi Allstate] #695650
05/12/10 10:03 AM
05/12/10 10:03 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I went out and checked my world aluminum block and it seems to be touching! meaning i couldnt tighten the nut down but it will fit if i put the cable on first before mounting the starter ( A body ) but ill anyway ...
Mopar Performance
Re: World Products block starter clearance issues [Re: moparniac] #695651
05/12/10 10:47 AM
05/12/10 10:47 AM
sg66mopar Offline
sg66mopar  Offline
I'll post some pics later today of how my mini was modified to work.
Two weeks ago I bought a Powermaster Ultra Torque High Speed # 9463. I had to grind and cut the s**t out of the block and starter but once it's done the battery stud problem is totally eliminated. The solenoid mounts on the outboard side of the starter, is clockable and has the terminals in the back instead of on the side. I'll post some pics of that also.
Re: World Products block starter clearance issues [Re: 440Jim] #695652
05/12/10 12:23 PM
05/12/10 12:23 PM
IN
BIG BEAR Offline
BIG BEAR  Offline
IN
I'll try to post some pics of our set up
Re: World Products block starter clearance issues [Re: Hemi Allstate] #695653
05/12/10 12:26 PM
05/12/10 12:26 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
There was a similar post on here about 2 months ago. I gave the guy the bracket off of a dakota starter. They have a brass strap that is bent out and down from the solonoid and puts the starter power stud pointing to the front of the car. then ya cut off the stud at the top, and you should clear. Ill check to see if I aquired any more parts since the last time I gave them away. I have 3 more cores since I gave him that part.
Kasey
Re: World Products block starter clearance issues [Re: BIG BEAR] #695654
05/12/10 12:29 PM
05/12/10 12:29 PM
IN
BIG BEAR Offline
BIG BEAR  Offline
IN
here is another one
Re: World Products block starter clearance issues [Re: BIG BEAR] #695655
05/12/10 12:35 PM
05/12/10 12:35 PM
IN
BIG BEAR Offline
BIG BEAR  Offline
IN
sorry this ones pretty dark
Re: World Products block starter clearance issues [Re: BIG BEAR] #695656
05/12/10 12:41 PM
05/12/10 12:41 PM
IN
BIG BEAR Offline
BIG BEAR  Offline
IN
here is the solenoid
Re: World Products block starter clearance issues [Re: Moparnut426] #695657
05/12/10 12:48 PM
05/12/10 12:48 PM
sg66mopar Offline
sg66mopar  Offline
Kasey
Kasey, that was me you gave the strap to and it helped a lot. I have it on my mini starter right now and I'm gonna get some pics posted by this afternoon.
I bought the Powermaster starter and the mini is just going to be a spare now.
Re: World Products block starter clearance issues [Re: sg66mopar] #695658
05/12/10 02:38 PM
05/12/10 02:38 PM
Chicago,Illinois
N
nosboy Offline OP
nosboy  Offline OP
N
Chicago,Illinois
It's a cast iron block.. I called around and WORLD said to use a MSD APS starter with an adaptor for wedge/hemi. I got a denso starter with an offset bracket relocating the B+ and solenoid terminals and I will try it this afternoon... Thanks for all the info and the pix... Gary Oles nosboy
Re: World Products block starter clearance issues [Re: nosboy] #695659
05/12/10 05:16 PM
05/12/10 05:16 PM
IN
BIG BEAR Offline
BIG BEAR  Offline
IN
Re: World Products block starter clearance issues [Re: BIG BEAR] #695660
05/12/10 07:02 PM
05/12/10 07:02 PM
Chicago,Illinois
N
nosboy Offline OP
nosboy  Offline OP
N
Chicago,Illinois
I talked to World Castings tech line and they told me MSD # 5098 and it DON'T look like it's clockable.. I think the .100 MIDPLATE puts my starter .100 closer to the rear of the engine because it DOES space out the trans .100 ... maybe I need a clockable 9523 from powermaster?????
