69 RR firewall Questions #695148
05/11/10 05:48 PM
05/11/10 05:48 PM
Mt. Eden Ky.
Hemi Allstate Offline OP
Mt. Eden Ky.
I have a couple holes in the firewall that I am not sure what they are for.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: 69 RR firewall Questions [Re: Hemi Allstate] #695149
05/11/10 05:49 PM
05/11/10 05:49 PM
Mt. Eden Ky.
Mt. Eden Ky.
Here is the other hole. Is this for the tach wire?
1996 Ram 1500 Sport
1968 road runner
Re: 69 RR firewall Questions [Re: Hemi Allstate] #695150
05/11/10 06:07 PM
05/11/10 06:07 PM
S.E. Wis
a4runer Offline
a4runer  Offline
S.E. Wis
Top picture I believe is Air Grabber cable hole,Not sure about second, the tach wire comes out a little above and to left(drivers side) of bulk head connector.
Re: 69 RR firewall Questions [Re: Hemi Allstate] #695151
05/11/10 06:39 PM
05/11/10 06:39 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
First pic is where air grabber cable comes through firewall, second pic is where factory tach wire comes through. If car is marked N96 on tag then someone drilled that hole.
Re: 69 RR firewall Questions [Re: Dougsmopars] #695152
05/11/10 09:56 PM
05/11/10 09:56 PM
Mt. Eden Ky.
Mt. Eden Ky.
OK , it does have a N96 on the tag. So, which hole has been added? The hole on the driver's side is too small for the grommet on the tach wire lead. Does this mean the tach was not an option factory installed on this car?
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
Re: 69 RR firewall Questions [Re: Hemi Allstate] #695153
05/11/10 10:03 PM
05/11/10 10:03 PM
Dougsmopars Offline
Dougsmopars  Offline
They might have drilled that hole to run a tach wire. I know the factory hole is in that area. I don't know the option code for factory tach. If you have a factory tach open up that hole till gromet fits.
Re: 69 RR firewall Questions [Re: Dougsmopars] #695154
05/11/10 10:24 PM
05/11/10 10:24 PM
Mt. Eden Ky.
Mt. Eden Ky.
Thanks for the responses guys.
I thought that the N96 was the air grabber code? Is that correct?
1996 Ram 1500 Sport
1968 road runner
Re: 69 RR firewall Questions [Re: Hemi Allstate] #695155
05/11/10 11:43 PM
05/11/10 11:43 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Yes.
I want my fair share
Re: 69 RR firewall Questions [Re: Hemi Allstate] #695156
05/12/10 09:18 AM
05/12/10 09:18 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes that is the Code for Air Grabber , ALL hemi cars had it .
The only way to know if it's an original tach car is to look at the Broadcast Sheet, it's not on the fender tag . the hole in your firewall on the drivers side is not in the correct location for the tach , added by a previous owner .
Re: 69 RR firewall Questions [Re: JohnRR] #695157
05/12/10 09:37 AM
05/12/10 09:37 AM
Mt. Eden Ky.
Mt. Eden Ky.
Thanks John
Mark
1996 Ram 1500 Sport
1968 road runner
Re: 69 RR firewall Questions [Re: JohnRR] #695158
05/12/10 07:11 PM
05/12/10 07:11 PM
69x Offline
69x  Offline
This is not correct, if a car came with a Tach it is on the fender tag, N85
Re: 69 RR firewall Questions [Re: 69x] #695159
05/12/10 08:32 PM
05/12/10 08:32 PM
It depends on what plant produced the car, I don't think Lynch Rd. built cars coded it.
Re: 69 RR firewall Questions #695160
05/12/10 10:48 PM
05/12/10 10:48 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
The passenger side is the A/G cable hole as others have said. The driver's side hole should have a bolt/stud with a washered nut... not sure what attaches, maybe the heater box or a brace.
XS
Re: 69 RR firewall Questions [Re: xs29j8] #695161
05/12/10 11:31 PM
05/12/10 11:31 PM
Mt. Eden Ky.
Mt. Eden Ky.
XS
WOW!!! I couldn't ask for more or better!!!
What an asset Moparts is!
Thank you XS
Mark
1996 Ram 1500 Sport
1968 road runner
Re: 69 RR firewall Questions [Re: xs29j8] #695162
05/13/10 07:25 AM
05/13/10 07:25 AM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
Here is another survivor pic showing the tach wire coming out of the correct area as well as the stud/nut out of the hole you are asking about.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: 69 RR firewall Questions [Re: 69x] #695163
05/13/10 09:30 AM
05/13/10 09:30 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
SHOW ME AN ORIGINAL TAG ... Please ...
Re: 69 RR firewall Questions #695164
05/13/10 09:32 AM
05/13/10 09:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Definitely not on ANY lynch rd. tag I have ever seen, including my tac equipped 69 Bee ...
Re: 69 RR firewall Questions [Re: Kowal] #695165
05/13/10 09:33 AM
05/13/10 09:33 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This begs the question .... where is his heater box ?
Re: 69 RR firewall Questions [Re: JohnRR] #695166
05/13/10 09:49 AM
05/13/10 09:49 AM
Mt. Eden Ky.
Mt. Eden Ky.
The heater box and associated parts were removed from this car for the installation of AC. All those original parts were gone when the car was brought to me, so I didn't realize that was a stud hole. I am not sure what part of the "ductwork" fastened there though?
Thank you Kowal for the picture.
1996 Ram 1500 Sport
1968 road runner
Re: 69 RR firewall Questions [Re: JohnRR] #695167
05/13/10 09:57 AM
05/13/10 09:57 AM
69x Offline
69x  Offline
You may be right about Lynch rd cars, but it was on the tag for St Louis cars, I dont think the poster said where his car was from
