sb roller lifters without tubing block?
#695095
05/11/10 04:28 PM
05/11/10 04:28 PM
Posts: 2,578 sweden
1Fast340
sweden
what smallblock solid roller lifters work without puting tubing in the block? thought my old trusted lifters would work since they are fairly closed around the wheel even after changing to a new block without the tubes in the gallery but i gues i was wrong from my simple measureing it seams like they uncover the holes about 1.5mm so what lifters should work? i have a .570/.576" lift comp XE roller cam and i realy dont want to take my shorblock apart again just for this even if it feels nice to know i found it in time..
Re: sb roller lifters without tubing block?
[Re: 1Fast340]
#695096
05/11/10 04:42 PM
05/11/10 04:42 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I used the new Comp roller lifters that are made to just drop in. They did not uncover the galley even with a .700+ lift cam.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Ron Silva]
#695099
05/11/10 06:04 PM
05/11/10 06:04 PM
Posts: 2,578 sweden
1Fast340
sweden
c
nice looking lifter, is there anykind of problem running those with standard oiling thru the rockershaft? seeing they are pushrod oiling?
from the partnumber i would gues thats a kit with all 16, i will look these up tomorow its not all that easy trying to order stuff around here where noone seems to know alot about smallblockmopars so its alot more sensible to have a partnumber when ordering than having someone look it up when ordering
thanks
[Re: JUST_N_TIME]
#695104
05/12/10 12:09 PM
05/12/10 12:09 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
I'd order from Brian - ou812 as he helped/did the design. I did anyway.
I have bought a couple sets of lifters among many other things through Brian. Great guy to deal with!
[Re: StrokerAspen]
#695106
05/12/10 02:31 PM
05/12/10 02:31 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
I bought mine through Brian as well. He is AWSOME to deal with. Comps are Pretty steep now I see.
kasey
