sb roller lifters without tubing block? #695095
05/11/10 04:28 PM
05/11/10 04:28 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
what smallblock solid roller lifters work without puting tubing in the block?
thought my old trusted lifters would work since they are fairly closed around the wheel even after changing to a new block without the tubes in the gallery but i gues i was wrong from my simple measureing it seams like they uncover the holes about 1.5mm
so what lifters should work?
i have a .570/.576" lift comp XE roller cam and i realy dont want to take my shorblock apart again just for this even if it feels nice to know i found it in time..
Re: sb roller lifters without tubing block? [Re: 1Fast340] #695096
05/11/10 04:42 PM
05/11/10 04:42 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I used the new Comp roller lifters that are made to just drop in. They did not uncover the galley even with a .700+ lift cam.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: sb roller lifters without tubing block? [Re: Jacob Pitt] #695097
05/11/10 05:12 PM
05/11/10 05:12 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
thats very impressive! is that with a full base cam or a reduced one? ok i gues i will look into those lifters, they are the ones with the linkbar on the inside if i remember right?
Re: sb roller lifters without tubing block? [Re: 1Fast340] #695098
05/11/10 05:24 PM
05/11/10 05:24 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
c
SRT DEMON ONE SEAT
Re: sb roller lifters without tubing block? [Re: Ron Silva] #695099
05/11/10 06:04 PM
05/11/10 06:04 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
c
nice looking lifter, is there anykind of problem running those with standard oiling thru the rockershaft? seeing they are pushrod oiling?
from the partnumber i would gues thats a kit with all 16, i will look these up tomorow its not all that easy trying to order stuff around here where noone seems to know alot about smallblockmopars so its alot more sensible to have a partnumber when ordering than having someone look it up when ordering
thanks
Re: sb roller lifters without tubing block? [Re: 1Fast340] #695100
05/11/10 06:14 PM
05/11/10 06:14 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Morel makes some also. you can get them thru erson cams.
Re: sb roller lifters without tubing block? [Re: Ron Silva] #695101
05/11/10 11:38 PM
05/11/10 11:38 PM
SoCal
Brian Hafliger Offline
SoCal
c
If you bought them from Comp you paid way too much!!
Brian Hafliger
Re: sb roller lifters without tubing block? [Re: 1Fast340] #695102
05/12/10 06:16 AM
05/12/10 06:16 AM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
I'd order from Brian - ou812 as he helped/did the design. I did anyway.
Re: sb roller lifters without tubing block? [Re: 1Fast340] #695103
05/12/10 11:13 AM
05/12/10 11:13 AM
South Carolina
a408swinger Offline
mopar addict
a408swinger  Offline
mopar addict
South Carolina
Doug Herbert lifters drop right in also. Thats what I run. I paid $219 for them but I think they are like $239 now. You just turn them around so the link bar is against the lifter valley. My cam has a .640 lift and Ive had no problems. Ive been running them for several years now.
Re: sb roller lifters without tubing block? [Re: JUST_N_TIME] #695104
05/12/10 12:09 PM
05/12/10 12:09 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
I have bought a couple sets of lifters among many other things through Brian. Great guy to deal with!
Re: sb roller lifters without tubing block? [Re: StrokerAspen] #695105
05/12/10 02:15 PM
05/12/10 02:15 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
i wouldnt mind ordering from Brian he for sure seems like a very good guy to deal with, i just dont know how to get the money to him since i honestly dont own a visacard or anything like that
Re: sb roller lifters without tubing block? [Re: StrokerAspen] #695106
05/12/10 02:31 PM
05/12/10 02:31 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I bought mine through Brian as well. He is AWSOME to deal with. Comps are Pretty steep now I see.
kasey
Re: sb roller lifters without tubing block? [Re: 1Fast340] #695107
05/12/10 06:01 PM
05/12/10 06:01 PM
SoCal
SoCal
Most guys in Australia and other parts of the world just send me a certified bank check and then wait the 7-10 days for it to clear. Then I ship USPS and it takes about 5-7 days to get it.
Shipping is around 100.00 give or take....
Brian
Brian Hafliger
Re: sb roller lifters without tubing block? [Re: Brian Hafliger] #695108
05/12/10 08:59 PM
05/12/10 08:59 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Don't have the part # in front of me, but our Comp rollers in our stroker 340 have cracked in several of the bodies. Roughly 53 passes on the combo. Not sure why, moderate cam, decent spring psi, no "at the moon shift point" (6700 iirc...) good pushrods. A strange harmonics perhaps?? who knows. I'm quite certain we're going to give the ones Brian has a try though.
