making ss springs #694597
05/10/10 11:36 PM
05/10/10 11:36 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
I would like to go old school and make my own set of ss springs for a 3800lb charger. Have heard nightmares about new 'mexico' springs and I have a few extra pairs of a-body springs laying around. does anyone have pictures of ss springs or leaf counts and measurements from axle mount point forward and back?
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: making ss springs [Re: kilroy] #694598
05/11/10 05:54 AM
05/11/10 05:54 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i think if you get the main spring made for the correct arch,weight you could use the extra spring leafs you have.how thick are the springs you have?[each leaf]
Re: making ss springs [Re: blownzoom440] #694599
05/11/10 10:29 PM
05/11/10 10:29 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
ok try different angle. Does anyone have pictures, close up pictures, maybe multiple pictures of their ss springs so I could try to recreate them? Cool. Thanks
Re: making ss springs [Re: kilroy] #694600
05/11/10 10:41 PM
05/11/10 10:41 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
SS springs will not only use, just more spring leaves, they will also be thicker and stronger.
But , you can gain spring stiffness with the idea you have. You will also need to utilize some strategic clamps also. mike
Re: making ss springs [Re: kilroy] #694601
05/12/10 03:41 AM
05/12/10 03:41 AM
ELYRIA,OH
ELYRIA,OH
here is 4 pics.i hope it helps.
Re: making ss springs [Re: blownzoom440] #694602
05/12/10 03:43 AM
05/12/10 03:43 AM
ELYRIA,OH
ELYRIA,OH
2
Re: making ss springs [Re: blownzoom440] #694603
05/12/10 03:44 AM
05/12/10 03:44 AM
ELYRIA,OH
ELYRIA,OH
3
Re: making ss springs [Re: blownzoom440] #694604
05/12/10 03:46 AM
05/12/10 03:46 AM
ELYRIA,OH
ELYRIA,OH
Re: making ss springs [Re: blownzoom440] #694605
05/12/10 08:11 AM
05/12/10 08:11 AM
Ma Mopar spent oh about a million of 1960 dollars and a full year at the track with the likes of McCandless etc to make them work--you ain't got a prayer --The Mexican springs are GREAT--all that talk is bs IMO Shocks at every corner and front end travel--setup, front eye location are the things folks get wrong and blame the springs--It takes a careful setup done by an experienced racer to get them to work like they should and WOW! They will work!!! To many folks get crappy shocks ( it said Drag shock in the catalog ) ---Honest...these days Cal Tracs are the way to go if you are racing and even they require a few months or longer of fine tuning to get the most out of--Buy some SS's--the 002 and 003 work best on most everything--they do loose some arch over time but that is not "wearing out"--buy some used--get great shocks like QA-1's or Koni SPA---BEST to find a racer that is hooking and get his advice-- We raced SS spings for over 18 years and found all this out the hard way but at the end had some bumper dragging A bodys! Good luck man!
Re: making ss springs [Re: ] #694606
05/12/10 08:42 AM
05/12/10 08:42 AM
scratchnfotraction Offline
Ma mopar already done the home work for you
get a set and dial them in
the caltracs are a good choise also
Re: making ss springs [Re: scratchnfotraction] #694607
05/12/10 10:15 AM
05/12/10 10:15 AM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
Is this for a street / strip car or just a strip car ?If its a dual purpose car i can see running them for looks.If its a drag only deal ,why not go real old school and get sum slapper bars ?Im dead hooking with them on 8 inch wide slicks .All it takes is to set them up properly (angle and location of snubbers).Best 60' of 1.54 on the tiny slicks and i know they will hold more power if my motor could make it (proly 1.4 60 foots).My Dart lifts front and back on the launch and plants the tires hard with no wheel hop .Mine are Old Foxcrafts from the 60's and were a Craigslist score for $35.00 ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: making ss springs [Re: blownzoom440] #694608
05/12/10 06:30 PM
05/12/10 06:30 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Hey thanks metalstorm for pics. Listen money is not what ive got, mortgage, and 3 kids and a lousy economy are issues. What I do have is spare parts and tools. Im working on a b body street/strip but I have added leafs to a-bodys with lots of success in past. So why not try it on a the charger. I patterned myself a "caltrac" and made my own but I dont have mono leaf springs so all it really does is stiffen up the suspension and keeps me from bending front leaf section. I like to tinker so I figure going old school and trying a ss spring "clone" would show me what was working or not. But I have bent many!! front spring sections on HD springs and regular springs. I figure ss springs have 2 to 3 extra front spring layers so maybe, maybe they wont bend? anybody got some more info for me and thanks!
Re: making ss springs [Re: kilroy] #694609
05/12/10 07:29 PM
05/12/10 07:29 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yes, the passenger side needs to be stiffer then the drivers side. I think the SS springs added a extra leaf.
If you dont add a extra leaf you can add clamps to the front spring segment on that side to gain the same effect.
In the end you wont have SS springs, but you will have stiffer springs that you can tune with clamps. With your past experience and depending on how fast you want to go, you should be able to make something work. mike
Re: making ss springs [Re: kilroy] #694610
05/12/10 09:32 PM
05/12/10 09:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What I did YEARS ago was clamping a 3/8 thick steel
plate to the front of the springs... same width as the
springs and also used a rear sway bar... did wonders
to my times
Re: making ss springs [Re: Sport440] #694611
05/12/10 09:36 PM
05/12/10 09:36 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Ok Ok ill bite. Im bitter because I hope I can duplicate them What aside from spring rate and pinion angle and ride height would be different that create the SS part? I know only an engineer or ma mope knows but.... really guys is it that big of a mystery?
Re: making ss springs [Re: MR_P_BODY] #694612
05/12/10 09:44 PM
05/12/10 09:44 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
I was thinking of reinstalling the sway bar I took off when I installed my "caltrac"s this will be on the list of trials. thanks 3/8"? WOW that would definitely stiffen things.
Re: making ss springs [Re: kilroy] #694613
05/12/10 10:12 PM
05/12/10 10:12 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yeah!!!, There Magic dont you know!!
Take my words Literally,
"In the end you still wont have SS springs"
But that doesnt mean you cant duplicate their similer effects.
Witch is to mostly stiffen both front and rear segments with more bias on the fronts and even more on the passenger side for a hopefully tuned outcome.
Theres no Mystery, accept to understand the axel rotation under power.
The driver side axel and the passenger side
Counter those movements with spring bias along with pinion rotation and you will be fine.
IMO, the Most important part is trying to overcome the rotational lift of the passenger side.
The next is controlling pinion rotation perimeters.
Further, probably anything you add to the stock springs to stiffen them up will be in the right direction. As long as you dont increase the down force on the driver side.
So have at it, And remember!
When its all done and said, you still "Wont have SS springs" mike
Post deleted by Defbob [Re: kilroy] #694614
05/12/10 10:14 PM
05/12/10 10:14 PM
Re: making ss springs #694615
05/12/10 10:21 PM
05/12/10 10:21 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
1st man invented wheel then figured out how to go faster then he got married and figure out how do do it cheaper
Re: making ss springs [Re: kilroy] #694616
05/12/10 10:28 PM
05/12/10 10:28 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
know this has been asked but my understanding of spring rate...
Set spring up side down (taking in account somehow for the friction on the floor) and measure weight to make spring drop and inch?
