NEED PAINTERS HELP
#694583
05/10/10 11:19 PM
05/10/10 11:19 PM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
i am getting ready to spray the exterior on my 68'dodge r/t, the question is, i have painted the door jambs, under the hood and in the trunk, my question is, how do i tape off these areas when i paint the rest of the car? i know if i tape it off can cause a seam,
Re: NEED PAINTERS HELP
[Re: Boise Chall]
#694586
05/10/10 11:52 PM
05/10/10 11:52 PM
Posts: 1,719 Middle of the mitten
69DodgeCharger
I do my cars the same way. I just tape mine off as best I can and after the outside paint is cured I use a bent razor blade to take off the hi area of the seam then wet sand it and hand buff it. it sucks doing it this way but I like single stage paint on trunk, jambs,inside of doors and under hood not as shiny. I like 2 stage paint outside super shiney. go to this site they are all paint and body guys they might have a better answer for you http://www.autobody101.com/forums/viewforum.php?f=5
Depends on if your using metallic or solid colors. As far as I know you can't wet sand single stage metallic without pretty much ruining it. At least I've never seen anybody get away with it. Solid colors you can wet sand and repair quite easily. If you look at it closely and take your time you will see there are points where the panels overlap or join for the inner fenders, trunk opening and door jambs that's where I taped mine off. It's a pain but it can be done.
[Re: Boise Chall]
#694590
05/11/10 04:31 AM
05/11/10 04:31 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
2 choices here: Tape it opposite of what you normally would do, paper toward the outside of the vehicle and then roll the paper backwards to create a soft edge. You are creating a little pocket between the paper and tape that paint can get it without being a sharp line. Or you can spend the big bucks and get the 3M DART tape. It's basically a tape with the built in soft edge and will allow you to tape the jambs without leaving a sharp line. Link Also as a side note base won't stand up for long without clear, and will most definitely fade with no UV protection.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: herkamer]
#694593
05/11/10 09:14 AM
05/11/10 09:14 AM
Posts: 4,922 new berlin wisconsin
Mr T2U
i use this product every day at work. the only problem you might have with it is if you spray a different color sealer before base coating you will see a sealer line in the jamb. 3M also makes a special tape to stop this. i will check with my paint supplier to get the proper name and number for it, i order it by anti sealer line tape from my paint supplier.
perception is 90% of reality
[Re: Hoof Hearted]
#694594
05/12/10 12:31 AM
05/12/10 12:31 AM
cornet684me
Brandon, Ms
yes, plum crazy on 68, my dad had a 70road runner with this color, i always loved it, i am building the car for me, it was a green, 318/904 it is now a plum crazy, 440/727, 3.55 sure grip , every thing r/t , it is cheaper to build what you want than to try to find a numbers matching r/t and pay 75,000.00 , i built my r/t for about 25000.00
[Re: Mr T2U]
#694595
05/12/10 12:34 AM
05/12/10 12:34 AM
cornet684me
Brandon, Ms
i talked with my paint guy today, he was telling me the 3m tape will work for me, he say if i am not use to doing the other tape thing, maybe easier for me to buy the tape, so i guess i will spend the money, thanks for all the input, i will post a pic once i get the paint on
