The HHR fan went out... #693862
05/10/10 11:35 AM
05/10/10 11:35 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Maybe they arent so wonderful afterall.. The HHR fan was less than one year old and only saw the occasional weekend street duty and at the strip..
Last weekend, I was on my way back from a car show about 40 miles away and notice the temp gauge creeping up.. I really didnt think too much of it, but kept an eye on it..
Yesterday, we took the Duster to the grocery store and instantly the temp shot up to 210 degrees.. I limped the car home, got out the volt meter and sure enough.. the HHR fan gave up the ship..
So maybe its not such a great idea to rely on these after market fans for those street driven cars like mine
Post deleted by Defbob [Re: Jeepmon] #693863
05/10/10 11:47 AM
05/10/10 11:47 AM
Re: The HHR fan went out... #693864
05/10/10 12:22 PM
05/10/10 12:22 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
maybe just a fluke there are HHR's out there with 100k plus still using the original fans may have just gotten a bad 1.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: The HHR fan went out... [Re: dusturbd340W5] #693865
05/10/10 01:06 PM
05/10/10 01:06 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I'm not sure if there is a difference from the OEM fans and the aftermarket fans that Rock Auto sell.. but the fan I have is made by a company called "TYC"..
Regardless, I ordered a new fan last night and should receive it shortly..
Re: The HHR fan went out... [Re: Jeepmon] #693866
05/10/10 02:04 PM
05/10/10 02:04 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Hey Jeep, just curious what alternator you are running. I have an HHR fan that I picked up this winter that I was about to install, but I heard some folks saying that the stock alternator won’t keep up with the power draw.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: The HHR fan went out... [Re: FlyFish] #693867
05/10/10 02:24 PM
05/10/10 02:24 PM
Renton Washington
Triple Threat Offline
Renton Washington
HHR fan, stock alternator here. My car is stored outside 24/7 365, easily 300+ passes and thousands of street miles later, still spinning away.
I bought mine direct from Eric though while he was at the GM dealership.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: The HHR fan went out... [Re: FlyFish] #693868
05/10/10 03:38 PM
05/10/10 03:38 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Stock alternator, just like Dustin runs... and up to just recently, I had no problems running the fan.. Even at night, there was no noticeable difference when running the fan and headlights at the same time..
Re: The HHR fan went out... [Re: Jeepmon] #693869
05/10/10 06:40 PM
05/10/10 06:40 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Thanks!
Re: The HHR fan went out... [Re: Jeepmon] #693870
05/10/10 09:00 PM
05/10/10 09:00 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
If it was aftermarket replacement compared to OEM....I would say that is probably the problem. I thought about buying an HHR fan too...but I wanted to make sure it was an OEM one if they are different.
PS...I still can't find that sticker...
Re: The HHR fan went out... [Re: Quicksilver440] #693871
05/11/10 11:22 AM
05/11/10 11:22 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I guess that is the question.. is the Rock Auto fans made by the OEM manufacture... or are they just aftermarket?? I thought they were OEM, but now I'm not so sure..
And no worries about the sticker.. you'll find it the moment I no longer need it.. lol
Re: The HHR fan went out... [Re: Jeepmon] #693872
05/11/10 11:50 AM
05/11/10 11:50 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Do the Rock Auto fans have a GM p/n on them?
Re: The HHR fan went out... [Re: bobby66] #693873
05/11/10 12:07 PM
05/11/10 12:07 PM
Akron Ohio
DartMan380 Offline
DartMan380  Offline
Akron Ohio
The ones Rock Auto sells are aftermarket made by TYC. TYC is a good company that makes about 75% of the aftermarket fans that are on the market.
If you guys have a Keystone Auto store around you check with them for a price. If you buy a fan from Keystone it will include a lifetime waranty on the motor.
Might want to check into that before buying one from Rock Auto...
Re: The HHR fan went out... [Re: bobby66] #693874
05/11/10 12:14 PM
05/11/10 12:14 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Not if they are tyc I would assume...same company that makes all the chinese reproduction headlights,taillights, etc..
Re: The HHR fan went out... [Re: OzHemi] #693875
05/11/10 12:22 PM
05/11/10 12:22 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I found this fan while looking at HemiFreds fan post... Its too bad I had already placed an order with Rock Auto for another HHR fan, or I would have bought this one...
http://www.flex-a-lite.com/auto/html/black-magic.html
Re: The HHR fan went out... [Re: Jeepmon] #693876
05/11/10 01:38 PM
05/11/10 01:38 PM
Kissimmee Fl.
Kissimmee Fl.
how much is the aftermarket fan from rock Auto because the oem fan from GM is not that much
Post deleted by Defbob [Re: dusturbd340W5] #693877
05/11/10 01:54 PM
05/11/10 01:54 PM
Post deleted by Defbob [Re: Jeepmon] #693878
05/11/10 01:56 PM
05/11/10 01:56 PM
Re: The HHR fan went out... #693879
05/11/10 02:05 PM
05/11/10 02:05 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
By far the best money I have ever spent. Writting it off because of one failure isn't the way to go. If that was the case none of us would/should by a single part mentioned on here.
gmpartsdirect.com has the complete setup for 73.00.
Hopefully your next one will give you long life.
Re: The HHR fan went out... [Re: RonP] #693880
05/11/10 04:40 PM
05/11/10 04:40 PM
L.I. N.Y. Hemi Street
HemiGreg Offline
HemiGreg  Offline
5000 CFM
Post deleted by Defbob [Re: HemiGreg] #693881
05/11/10 04:56 PM
05/11/10 04:56 PM
