Running problem with 99 cummins
#69370
06/07/08 07:47 PM
06/07/08 07:47 PM
Posts: 8,180 Detroit, MI
CokeBottleKid
Detroit, MI
Well I'm getting involved in my schools (Cal Poly Pomona) I.C engines lab. They received a donated 99 cummins 24 valve motor from Banks performance to use as a dyno mule for students senior projects. 2 students already did their project on assembling it, adding an air-water aftercooler and hooking it up to one of our dyno's. They didn't get too far on it because of a dyno issue (pump is from the 50's), they got it idling but said they could open the throttle and the motor would just continue idling basically . They're running just the stock 99 truck injection setup, ECU and all. I'm basically picking up where they left off, I know basically nothing about diesels but I can work my way around EFI pretty well. So anyone have any ideas where to start looking. I assume this system uses some type of OBDII setup yes? Where can I get a good scanner/logger?
Re: Running problem with 99 cummins
[Re: CokeBottleKid]
#69378
09/27/08 12:30 PM
09/27/08 12:30 PM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
Eric There may be, but since I have all that on hand I honestly have never looked elsewhere to know for sure.
Hopefully someone else can answer that.
Good luck with it
Rick
Blown71X V2.0 under construction
71 Cuda 383 4-SPD (maybe for sale)
2010 Challenger B5 Classic
[Re: crlush]
#69380
09/27/08 08:50 PM
09/27/08 08:50 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
check throttle position sensor thats what happened to my friends diesel you could push throttle and it would only idle. hope this helps
Make sure you have fuel pressure to the injection pump too.
[Re: NITROUSN]
#69387
09/28/08 11:35 AM
09/28/08 11:35 AM
Posts: 6,563 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Well that is how it was explained to me. I have seen the inside of a few 3406 Cat injector pumps and because they use plunger and barrels with individual fuel lines I assumed the VP44 used a similar arrangement. I saw no reason to doubt what I was told. How the pump works not withstanding, once he added some lubricity to the fuel with the outboard motor oil it quit with the nothing happens when you step on the peddle routine. If you could post a link to some internal pics and info on a VP44 I promise I won't wait 'till I'm bored to educate myself on its operation. Kevin
