Re: Getting white lettering off tire?
[Re: ademon]
#693461
05/09/10 09:06 PM
05/09/10 09:06 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
usually the white lettering is white rubber embossed into the rubber itself. If you try to scrape or take it off with abrasive, you usually end up with more white showing than you had before. I've seen guys use dyes, and markers to delete/cover them, but depending on the tire, I don't think you can remove it.
[Re: ademon]
#693464
05/09/10 10:13 PM
05/09/10 10:13 PM
Posts: 2,034 NW Indiana
deansrr
NW Indiana
they use to make a black tire dye, we use to use it cover white walls, but don't know if it is still made, I think it was called Tire Black
1973 Road Runner
1974 Satellite (for sale)
1973 240z (wifes)
1993 Ramcharger (thanks Devil)
2002 Honda S2000
[Re: jcastle1]
#693470
05/10/10 03:26 PM
05/10/10 03:26 PM
Posts: 7,367 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
After 72 hours you can apply your favorite tire dressing on them(which should be ArmorAll matt or gloss.)
I thought ArmorAll was a no no.
Doesn't it turn the rubber brown?
[Re: burdar]
#693471
05/10/10 03:32 PM
05/10/10 03:32 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I used black vinyl spray paint. It got the job done if you don't like it you just scrub off the paint.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
