need some help #692578
05/08/10 07:39 PM
05/08/10 07:39 PM
mo
Mr. Mojo Risen Offline OP
Justa 'member'
Justa 'member'
mo
my 68 dart has been sittting in the garage for about three years. well i tried to push it out today and it wouldnt move. i had it in neutral and the emergency brake wasnt on. i jacked it up and the drivers side wheel spun both directions but the passengers side was locked up. do you guys think the rearend is screwed up or maybe my brake is just locked up?
I wish i was you, so I could hang out with me.
Re: need some help [Re: Mr. Mojo Risen] #692579
05/08/10 07:56 PM
05/08/10 07:56 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Brakes can seize from sitting, but rearend, not likely
Re: need some help [Re: Mr. Mojo Risen] #692580
05/08/10 08:16 PM
05/08/10 08:16 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
Brakes rust...
Re: need some help [Re: terzmo] #692581
05/08/10 08:28 PM
05/08/10 08:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it was parked with the emergency brake on the cable may be rusted in place. You can spray the cable housing with PB blaster and free it up.
Re: need some help [Re: stumpy] #692582
05/09/10 06:45 AM
05/09/10 06:45 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
Happened on bro in law's Roadrunner. Rusted drum. Took off the wheel and beat the (brake)drum with a dead blow hammer.
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: need some help [Re: runinonmt] #692583
05/09/10 08:27 AM
05/09/10 08:27 AM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
Re: need some help [Re: stumpy] #692584
05/09/10 11:35 AM
05/09/10 11:35 AM
I'd spoon the linings back and or use a bar inbeween/thru the studs to lever it loose/get it to rotate (protect the threads w extra lug nuts). You can hit the drum around the center register w a hammer/drift and or pry appropriately around the drum lip to break it loose but I try to use pry bars/bfh's as a last resort.
Re: need some help [Re: RapidRobert] #692585
05/09/10 11:40 PM
05/09/10 11:40 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have a Coronet 8 3/4 in my Duster. The oil seal was a POS and allowed gear oil to seep past. The oil leaked into the brakes and congealed to the point where the wheel was hard to spin. My symptoms were similar to yours. I had to replace the shoes and clean everything with solvent. Its all okay now since I replaced the oil seals and foam flange gaskets.
Re: need some help [Re: Kern Dog] #692586
05/10/10 08:19 PM
05/10/10 08:19 PM
mo
Justa 'member'
Justa 'member'
mo
thanks fellas
