Re: Question on porting. **PICS** [Re: Pyper70] #692241
05/09/10 02:42 PM
05/09/10 02:42 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
See, the hole just keeps getting deeper ! Told you to leave the friggin' things alone but n-o-o-o-o-o ...
Re: Question on porting. **PICS** [Re: Stanton] #692242
05/09/10 04:10 PM
05/09/10 04:10 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
You will more than likely have aluminum and abrasive stuck in the assembly lube Edelbrock uses. Should have disassembled them. To do it now, you'll also need new valve seals because the seals will get trashed taking the valves out to clean them... So you might pull the psrings and using brake clean clean off the head of the valve, the seat, and the guide areas without removing the valve. As was said... this is part of why you here "have them corrected" at a shop instead of running them out of the box.
Re: Question on porting. **PICS** [Re: Stanton] #692243
05/09/10 05:04 PM
05/09/10 05:04 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Why ya gotta be so mean?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Question on porting. **PICS** [Re: Pyper70] #692244
05/09/10 05:10 PM
05/09/10 05:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
They're most likely umbrella seals and there's no reason you shouldn't be able to reuse them.
Re: Question on porting. **PICS** [Re: moper] #692245
05/09/10 05:12 PM
05/09/10 05:12 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Even though I shoved a wet rag and did all what I wrote before AND had a towel covering the valve train? I dont see how abrasive dust and aluminum would have gotten anywhere. Sure maybe very little...but I went through with brake cleaner and pressurized air through the head twice and taped it off and put a valve cover on.
Re: Question on porting. **PICS** [Re: Pyper70] #692246
05/09/10 09:25 PM
05/09/10 09:25 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I would take them apart. Tootsie roll grit is unforgiving
Re: Question on porting. **PICS** [Re: BSB67] #692247
05/10/10 02:06 AM
05/10/10 02:06 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Got it...I'll strip em today and clean em all up.
Re: Question on porting. **PICS** [Re: Pyper70] #692248
05/10/10 02:40 AM
05/10/10 02:40 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
VERY wize choice!! Remember, you still will have fine hot shavings get down in some areas that can't be seen (& they "stick" there), even though you stuff a wet rag into the ports, pulling them out & blowing compressed air in the valve area (when the valve is on the seat) is a BIG NO NO, you can/will force any tiny shavings around the seat area & they will stay there, then once the valve starts opening it'll most likely end up between the seats of the valve & fuse there, do you know what that means . Please do it "right" & disasemble them completely, then clean them very well before assembly.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Question on porting. **PICS** [Re: joedust451] #692249
05/10/10 02:55 AM
05/10/10 02:55 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The plug you want is either ND Q16PR-U11 or NGK NGKR5672A-8
Re: Question on porting. **PICS** [Re: 1_WILD_RT] #692250
05/10/10 08:58 AM
05/10/10 08:58 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
They didn't have a R5672....Said special order of 10 days and about $6.50 / plug
Got the factory cross reference for the Champion...the NGK BKR5E.
When I get to the States I'll buy 2 sets of the one you mentioned and have them on hand.
Thanks for the number
Re: Question on porting. **PICS** [Re: Pyper70] #692251
05/10/10 12:38 PM
05/10/10 12:38 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Factory plugs are designed for stock heads.. Edelbrock heads require 3/4" reach plugs..
Re: Question on porting. **PICS** [Re: 1_WILD_RT] #692252
05/10/10 01:00 PM
05/10/10 01:00 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
The BKR5E are the 3/4" threads...for the 3/4" threaded Champions
Re: Question on porting. **PICS** [Re: Pyper70] #692253
05/10/10 05:16 PM
05/10/10 05:16 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The valve stems shred the interior (sealing surface) if you remove them totally and pull the lock groove thru them. This would be why new seals come with the sleeve for the valve stem. They are not standard seals. I just buy the Edelbrocks for peace of mind.
Re: Question on porting. **PICS** [Re: moper] #692254
05/10/10 05:49 PM
05/10/10 05:49 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
So I could in theory just take the valve keepers off, remove the spring, push the valve a little off the seat, put in some carb spray and blow air in it, then dry it with a lint-free cloth and reassemble it. It'll take 3 weeks before I can get another set of seals.
