Super stock spring question #692162
05/08/10 10:11 AM
05/08/10 10:11 AM
Ohio
fiddlestix Offline OP
Ohio
Can anyone tell me if super stock springs with the b-body front hangers will change my wheel base? I am changing to Dana 60 in an otherwise stock Challenger.
Re: Super stock spring question [Re: fiddlestix] #692163
05/08/10 10:34 AM
05/08/10 10:34 AM
wisconsin
jp66charger Offline
jp66charger  Offline
wisconsin
Don't know much about E bodies, but I can tell you that super stock springs have a 20" front segment, same as factory A body. In a B body car you need to order a longer front perch to compensate for shorter front segment. I can only assume it would be the same for the challenger, but Mancini could answer that question with one phone call. Good luck, JP.
Re: Super stock spring question [Re: jp66charger] #692164
05/08/10 10:38 AM
05/08/10 10:38 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
'65-up b and all E have 22" front segment so will need the 2" extended hanger to use superstock springs with a 20" front segment.
Re: Super stock spring question [Re: fiddlestix] #692165
05/08/10 10:55 AM
05/08/10 10:55 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
fiddlesticks
You will need the 2" longer front spring perch for the S/S spring with the 20" front segment.
....and no it will not change your wheelbase
Re: Super stock spring question [Re: roadhazard] #692166
05/08/10 12:34 PM
05/08/10 12:34 PM
Ohio
Ohio
Thanks guys. That helps!!
