upgrade to toyota alternator #691205
05/07/10 03:21 PM
05/07/10 03:21 PM
BC Canada
cudasam Offline OP
cudasam  Offline OP
BC Canada
I have a challenger and have replaced my original alternator with a nippondenso out of an 88 toyota forerunner. I ran the sense wire to my starter relay, but it is a closed circuit and is draining my battery, Does the alternator have a short, or does the sense wire have to be connected to a switched terminal?
Re: upgrade to toyota alternator [Re: cudasam] #691206
05/07/10 04:00 PM
05/07/10 04:00 PM
Andrewh Online content
Andrewh  Online Content
sensing wire should be key on.
you should be able to tap off the same line that the original vr was linked up to. Blue I think.
Re: upgrade to toyota alternator [Re: cudasam] #691207
05/07/10 04:46 PM
05/07/10 04:46 PM
AndyF Offline
AndyF  Offline
Double check your wiring instructions. The Denso alternators in the kit I make use an ignition wire which is keyed. The sense wire is always hot as is the power wire.
http://www.arengineering.com/alternatorbracket/ND_bracket/denso.html
Re: upgrade to toyota alternator [Re: Andrewh] #691208
05/07/10 11:40 PM
05/07/10 11:40 PM
BC Canada
cudasam Offline OP
cudasam  Offline OP
BC Canada
Yes,I think this is correct. Thank you very much. !!!
Re: upgrade to toyota alternator [Re: AndyF] #691209
05/07/10 11:44 PM
05/07/10 11:44 PM
BC Canada
cudasam Offline OP
cudasam  Offline OP
BC Canada
I think the sense wire on my challenger has to be keyed on. I originally hooked it up to the starter relay(always hot), but when I did this, my battery was draining when the car was sitting. I took the negative terminal off the battery and put a tester between the terminal and the post, and was discharging 11.67 volts. I unhooked the sense wire and it dropped to a .01 volts. Thanks for the info on the kits !!
Re: upgrade to toyota alternator [Re: cudasam] #691210
05/08/10 08:00 AM
05/08/10 08:00 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
The owner of the Dart I purchased made the same mistake and it drains the battery if parked a long time.
Re: upgrade to toyota alternator [Re: gdonovan] #691211
02/27/11 03:06 AM
02/27/11 03:06 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
So you take the wire going into the old VR and run it to the sense wire of the denso unit?
Will your old ammeter work?
Need to know I'm going to dry run this setup in my car to test it out before I run it in the rebuilt motor.
Re: upgrade to toyota alternator [Re: autoxcuda] #691212
02/27/11 04:19 PM
02/27/11 04:19 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Bump. Need help on this.
