Put new 1" Torsion bars in & Coronet now rattles ? #690819
05/06/10 10:50 PM
05/06/10 10:50 PM
Kenosha, WI wi/il border
BobN Offline OP
BobN  Offline OP
Put new 1" Torsion bars in Coronet now rattles Gisbt the headers, what to do?
drives me mad,from engine vibrations causes to headers rattle against torsoin bar
do i have to frbt mt headers???
how do uo do this?
Re: Put new 1" Torsion bars in & Coronet now rattles ? [Re: BobN] #690820
05/06/10 10:55 PM
05/06/10 10:55 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Can you rephrase the question??!!!
Re: Put new 1" Torsion bars in & Coronet now rattles ? [Re: BobN] #690821
05/06/10 10:56 PM
05/06/10 10:56 PM
IN
ahy Offline
ahy  Offline
IN
Your headers must have been real close before the swap. Time to adjust the headers with a hammer or get new headers. It would also be worth checking motor mounts. Are they up to snuff or is the motor "slumping". Replacing or shimming up the mounts may be an option.
Re: Put new 1" Torsion bars in & Coronet now rattles ? [Re: BobN] #690822
05/07/10 12:26 AM
05/07/10 12:26 AM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
Mine did the same thing when I put in larger bars.
My header / T bar rubbing was on the drivers side til I dropped it in reverse and did a short burnout in reverse.
No more rubbin.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Put new 1" Torsion bars in & Coronet now rattles ? [Re: BobN] #690823
05/07/10 02:51 AM
05/07/10 02:51 AM
midwest
I
intragration Offline
I
midwest
I never had a problem with clearance on mine. Restored it, put the same parts back in, and suddenly had 1/4" interference between the header and the torsion bar. I tried every single possible way to clearance the header prior to installing the torsion bar, I couldn't make up the 1/4". Finally, put a very heavy, 4' long bar in the end of the header and went nuts on it. Surprisingly, I was able to angle the header just enough to give me the 1/4" plus about 1/8" more with no ill effects.
Re: Put new 1" Torsion bars in & Coronet now rattles ? [Re: intragration] #690824
05/07/10 03:31 AM
05/07/10 03:31 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have the same 1" MP torsion bars in my 70 Charger . The Hooker headers # 5903 hit the drivers side T bar. I took a chunk of sidewall from a tire and jammed it between them. Its redneck, but it worked.
I later switched to Hooker #5209 headers and it was just as bad. I now have TTI pipes. ZERO problems. They cost a weeks pay, but were worth it.
Re: Put new 1" Torsion bars in & Coronet now rattles ? [Re: Kern Dog] #690825
05/09/10 08:21 AM
05/09/10 08:21 AM
S.E. Wis
a4runer Offline
a4runer  Offline
S.E. Wis
Bob, Bob, Bob how many of us told you that changing the t-bars was not needed.............?
Bruce
Re: Put new 1" Torsion bars in & Coronet now rattles ? [Re: a4runer] #690826
05/09/10 10:24 AM
05/09/10 10:24 AM
BobN Offline OP
BobN  Offline OP
thanks Mr Ford . always appriciatte a nice jab.
it handles nices though!~ I like that!
just sounds like a kid in my back seat playing drums on pots & pans.??? yikes
I will have this fixed next Monday at Dons.
gonna ding the header,Its cheapest option!
Re: Put new 1" Torsion bars in & Coronet now rattles ? [Re: BobN] #690827
05/09/10 10:57 AM
05/09/10 10:57 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Can you just shim up the motor mount on the side that rattles? Worked on my '66 Charger.
