what to do with new sending units?! junk? #690804
05/06/10 10:43 PM
05/06/10 10:43 PM
Kenosha, WI wi/il border
BobN Offline OP
BobN  Offline OP
i had replaced my old sending unit on my 68 coronet and the new one was formMancinis. registes only q/4 tank or always on empty.
today we oull it and I put in a new one fomVans in WI ans same think -Bearely reading any gass!!!!
[Edited by Moparts - Family Friendly Site - Keep it clean] ? really what do I have to do?
we checked wire with vilt gaugw all good.
we ran shock and got the gauge in the dash work and read full,
when remove that goes to 'e' again
HELP, do i buy another one frm someone else?
hopefully i get one that works?
WHAT DO DO WITH THESE SENDING UNIT ISSUES???
Re: what to do with new sending units?! junk? [Re: BobN] #690805
05/06/10 10:56 PM
05/06/10 10:56 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Dixie resto parts has them and claim to be made by the original supplier for Chrysler. I took a good original sending unit and connected it to a Spectra pick up with hose clamps works great.
Re: what to do with new sending units?! junk? [Re: BobN] #690806
05/06/10 11:47 PM
05/06/10 11:47 PM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
I got a new one from Auto-zone for my '69 coronet, and it works great! about $70 I think...
Re: what to do with new sending units?! junk? [Re: cornucopia] #690807
05/07/10 12:48 AM
05/07/10 12:48 AM
hooziewhatsit Offline
There was another guy here who had luck making his sender work better by adding another ground wire from the swinging arm to fuel pick up rod. Not sure if it'll help in your case or not.
Re: what to do with new sending units?! junk? [Re: hooziewhatsit] #690808
05/07/10 12:59 AM
05/07/10 12:59 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Are you using the ground strap between the sender and the fuel tubing?
Re: what to do with new sending units?! junk? [Re: Snoopy] #690809
05/07/10 06:32 AM
05/07/10 06:32 AM
Ohio
dobie Offline
dobie  Offline
Ohio
Good luck is all I'll say. I gave up after going thru two of them. One from Herb's Parts, and one from Auto Zone.
https://board.moparts.org/ubbthreads/show...part=1&vc=1
1968 Plymouth Road Runner 383 4 speed
Re: what to do with new sending units?! junk? [Re: Snoopy] #690810
05/07/10 08:05 AM
05/07/10 08:05 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Where did you get this 8" long ground strap. I bought one from ebay and it is only 3 3/4". Not long enough for my application. My guage reads 3/4 when the tank is full.
Scott
1969 Super Bee, 383/4 speed
Re: what to do with new sending units?! junk? [Re: dobie] #690811
05/07/10 09:01 AM
05/07/10 09:01 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Yup, they're junk!
Re: what to do with new sending units?! junk? [Re: dmerc] #690812
05/07/10 11:57 AM
05/07/10 11:57 AM
CA
mojavered Offline
mojavered  Offline
CA
If you buy another, try rosevillemoparts.com. They are a pretty good company to deal with.
71 Challenger RT
440 / 727 / 8.75
Re: what to do with new sending units?! junk? [Re: hooziewhatsit] #690813
07/08/10 07:48 PM
07/08/10 07:48 PM
541 slobovia
A990 Online content
A990  Online Content
541 slobovia
I've just spent 15 minutes searching for that post, but no luck. Any ideas which forum and so forth?
Re: what to do with new sending units?! junk? [Re: A990] #690814
07/08/10 08:22 PM
07/08/10 08:22 PM
BDW Online content
BDW  Online Content
If you still have the original you might be able to fix it. It's fairly easy to bend the tabs and open the cover.
I just got done with mine. Usually the windings are ok and the wiper arm is the problem. In my case the connection point had corroded and the arm fell off. If this is the case, it's quite easy to clean it up and solder it back on.
If the windings are damaged (open) it's probably not worth trying to fix it.
I really wish I had taken some pics, unfortunately I was in such a hurry to get it working, I didn't.
Re: what to do with new sending units?! junk? [Re: BDW] #690815
07/08/10 08:52 PM
07/08/10 08:52 PM
S.E. Wis
a4runer Offline
a4runer  Offline
S.E. Wis
I just got one from 521 restorations he was selling them in the b-body parts section with a good price. Tested it before I installed it and it read fine thru full travel and seemed to read what I put back in the tank after draining it to swap senders. These are the 3/8 outlet with a return on them but the return can be plugged. You can also mini clamp a ground wire on the return and run it to the bolt in the body that holds up the fuel line above the right front corner of the tank,for those missing the hogey ground strap.Juat my 2cents but these did work and other "new' ones did not...Bruce
Re: what to do with new sending units?! junk? [Re: a4runer] #690816
07/09/10 11:21 AM
07/09/10 11:21 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I also went through a couple of senders and had the 3/4 indication problem. When I finally compared the new one to the original more closely I found that the swing arm travel was more on the new one (about a 3/4" or so). I had the correct resistance readings at both ends of the travel which threw me off. With the longer swing it was hitting the top of the tank before the end of the swing travel. A slight bend in the arm was all that was needed to correct it. Now it reads full on the gauge with a full tank of gas.
Good Luck
Re: what to do with new sending units?! junk? [Re: 68jim] #690817
07/09/10 12:18 PM
07/09/10 12:18 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The reason most dont work is because people dont check them for arm swing compared to the old one.That and some forget the ground.I run a wire from the sender to the body for a ground as here the strap rusts off quick.That and remember the gauges werent that accurate even new.Gad a few new cars in the 60s and 70s that the gauges were off.Rocky
Chrysler Firepower
Re: what to do with new sending units?! junk? [Re: A990] #690818
07/09/10 01:12 PM
07/09/10 01:12 PM
I believe it was in the General Forum, where the threads get deleted after so long. I took a quick look but didn't find it.
I believe the guy had intermittent issues where at 3/4 tank, it would drop to empty, then it would work again at 1/2 tank. He found that the swinging arm was losing its ground to the rest of the sender at certain points along its travel. So, he added another wire from the arm to the sender body to give it a good ground, and it worked great after that.
