How much radiator do I need??? #690777
05/06/10 09:49 PM
05/06/10 09:49 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
My new engine has shown me I need a bigger radiator. I'm looking for sugustions on how big.
The old radiator is for a Ford Ranger II, it is 18" x 18" x 1", one row core, alum core and plastic tanks. It worked good with my old engine, but it only had 10:1 comp, iron heads and "loose". I could make three 1'8 mile passes, back to back to back and would actually cool down going back to the staging lanes.
New engine has 13.5:1, alum heads and is "fresh". I pull out of staging lanes at 140*, do burn out, make pass and back to the trailer its 195* and takes 10-12 min to come down to 145*. My concern is to not put more than is needed, because of the weight of the water in the radiator.
Anyone have any ideas?
Thanks, Brian
Re: How much radiator do I need??? [Re: '72CudaRacer] #690778
05/07/10 07:57 AM
05/07/10 07:57 AM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
Call Smith's Radiator at 765-478-5325. They specialize in Mopar radiators for street and strip. They aren't cheap but build a quality piece.
I'm using their radiator in my street 432 Hemi, without a water pump fan, and my temp. stays at 185 degrees all day long.
Re: How much radiator do I need??? [Re: Mopar Grandpa] #690779
05/07/10 08:00 AM
05/07/10 08:00 AM
Jamey Offline
Jamey  Offline
Don't be in a hurry to get one from Smith's. It took forever to get mine from them.
Re: How much radiator do I need??? [Re: Jamey] #690780
05/07/10 09:19 AM
05/07/10 09:19 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I run the cheap summit radiator (northern I think) and the HHR fan and I can make back to back passes all day and the car will cool back to 150 or so in short order. I can shoot you some more info or pics later if you like.
Re: How much radiator do I need??? [Re: RonP] #690781
05/07/10 03:03 PM
05/07/10 03:03 PM
tboomer Offline
tboomer  Offline
Brian...I bought a Griffin when they were on sale at Summit..I think it was around 175.00...Also use a Mezerie water pump...Never had any cooling issues with that setup...
Re: How much radiator do I need??? [Re: RonP] #690782
05/07/10 03:08 PM
05/07/10 03:08 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Well that makes me feel good as I have the same setup! I run the meziere 55gpm drop in unit also so hopesfully she stays cool like yours!
Mopar Performance
Re: How much radiator do I need??? [Re: moparniac] #690783
05/07/10 05:10 PM
05/07/10 05:10 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
PM moparacer (Darhl Clark) He is a member & owns Clarks Radiator shop in Everette Pa. He made me a killer deal on a Becool rad & return bottle a couple of months ago.
Re: How much radiator do I need??? [Re: RonP] #690784
05/07/10 05:53 PM
05/07/10 05:53 PM
TN
65racer Offline
2009 IHRA World Champion
65racer  Offline
TN
I run the cheap summit radiator (northern I think) and the HHR fan and I can make back to back passes all day and the car will cool back to 150 or so in short order. [/quote
How's it going Brian??????????
Same here, except I use the cheap moroso electric fan, on mine no problems in 3 years with this set up.
Save your $$$$$, go with the summit radiator, will do the job nicely.
Re: How much radiator do I need??? [Re: 65racer] #690785
05/08/10 10:13 PM
05/08/10 10:13 PM
Mooresburg, Tn
Mooresburg, Tn
Hey Champ,
I sent you a PM.
What size radiator are you guys running? How thick, plastic, alum?
Thanks,
Brian
