How much radiator do I need???
#690777
05/06/10 09:49 PM
05/06/10 09:49 PM
Posts: 2,039 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
My new engine has shown me I need a bigger radiator. I'm looking for sugustions on how big. The old radiator is for a Ford Ranger II, it is 18" x 18" x 1", one row core, alum core and plastic tanks. It worked good with my old engine, but it only had 10:1 comp, iron heads and "loose". I could make three 1'8 mile passes, back to back to back and would actually cool down going back to the staging lanes. New engine has 13.5:1, alum heads and is "fresh". I pull out of staging lanes at 140*, do burn out, make pass and back to the trailer its 195* and takes 10-12 min to come down to 145*. My concern is to not put more than is needed, because of the weight of the water in the radiator. Anyone have any ideas?
Thanks, Brian
Re: How much radiator do I need???
[Re: RonP]
#690784
05/07/10 05:53 PM
05/07/10 05:53 PM
Posts: 1,235 TN
65racer
2009 IHRA World Champion
TN
I run the cheap summit radiator (northern I think) and the HHR fan and I can make back to back passes all day and the car will cool back to 150 or so in short order. [/quote
How's it going Brian??????????
Same here, except I use the cheap moroso electric fan, on mine no problems in 3 years with this set up.
Save your $$$$$, go with the summit radiator, will do the job nicely.
[Re: 65racer]
#690785
05/08/10 10:13 PM
05/08/10 10:13 PM
'72CudaRacer
Mooresburg, Tn
Hey Champ, I sent you a PM.
What size radiator are you guys running? How thick, plastic, alum? Thanks, Brian
