Top Fuel Hemi similar to OEM Hemi? #690756
05/06/10 09:43 PM
05/06/10 09:43 PM
Heart of Ohio
4boxers4 Offline OP
4boxers4  Offline OP
Heart of Ohio
In a discussion about the hemi used in top fuel, my friend said no parts from an OEM Hemi will 'fit' the Top Fuel Hemi. I thought that some would (but obviously for fitment only). Am I wrong? Anyone know specifics or have links to cool sights on this topic, or on what will or won't fit, please?
Thanks!
Persistance is omnipotent Durability Engineer, Chair and Couch division...
Re: Top Fuel Hemi similar to OEM Hemi? [Re: 4boxers4] #690757
05/06/10 10:00 PM
05/06/10 10:00 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
There are probably a "few" items which would still fit but after 45 years of use in top fuel the original motor design has been tweeked for the purpose.
The distributor would probably fit. Timing cover. Oil pump. Oil pan. They're dry blocks so there are no waterpump provisions.
Re: Top Fuel Hemi similar to OEM Hemi? [Re: 4boxers4] #690758
05/06/10 10:12 PM
05/06/10 10:12 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
They share the same bolt patterns, but's that's about all.
I have 2 complete fresh long blocks laying around, TAD motor but very simalar .
A pair of BAE billet heads all fresh with new titaninum valves and valve springs, 10K RPM capable.
All the fixens to go with it,
I have rebuilt these motors dozens of times, they sit with new internals ready for battle.
Re: Top Fuel Hemi similar to OEM Hemi? [Re: Challenger 1] #690759
05/07/10 07:02 AM
05/07/10 07:02 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Depends what technology level you are talking about. 40 years ago I would venture a guess that almost everything fit as the only components available were stock parts. As time went on and the aftermarket started producing parts, I would think there would have been less and less compatibility with OEM. Just my .
Re: Top Fuel Hemi similar to OEM Hemi? [Re: 6PakBee] #690760
05/07/10 07:33 AM
05/07/10 07:33 AM
Cincinnati, Ohio
Cincinnati, Ohio
exactly...
Re: Top Fuel Hemi similar to OEM Hemi? [Re: Challenger 1] #690761
05/07/10 09:23 AM
05/07/10 09:23 AM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
Well it sounds like some parts will bolt on so his "assuming chevy" friend is incorrect.
Re: Top Fuel Hemi similar to OEM Hemi? [Re: Blakcharger440] #690762
05/07/10 10:05 AM
05/07/10 10:05 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Crank shafts and some rods depending if the use 2.375 or 2.20 bearing rods. heads are the same bolt pattern and so on.
Re: Top Fuel Hemi similar to OEM Hemi? [Re: Dodgem] #690763
05/07/10 11:36 AM
05/07/10 11:36 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Even though the Top fuel hemis are not 100% intechangable with a passenger car hemi those engines share a hell of alot more with the street hemi than with an LS-6 454 or a 427. Ask you buddy how come the Chevy top fuel cars do not run a variation of a 427 or 454.
Keep old mopars alive.
Re: Top Fuel Hemi similar to OEM Hemi? [Re: Dodgem] #690764
05/07/10 11:58 AM
05/07/10 11:58 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
The question I would pose is "What parts WON'T bolt on? Pistons are different..... thats about it. Not long ago they specified stock intake rockers that would break off in a backfire or hydro lock condition.
Its a bored and stroked 426 hemi made out of aluminum.
What dimensions on the block won't allow stock components?
Re: Top Fuel Hemi similar to OEM Hemi? [Re: RemCharger] #690765
05/07/10 12:30 PM
05/07/10 12:30 PM
Cincinnati, Ohio
Cincinnati, Ohio
No way are they running stock rockers, with Nitro? Heck even the heads are different that won't allow stock rockers. BTW a new set of rockers are close to 5 grand, there not stock.
And the OP didn't say anything about chevys...
Re: Top Fuel Hemi similar to OEM Hemi? [Re: Challenger 1] #690766
05/07/10 12:56 PM
05/07/10 12:56 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Its not stock rocker arms they are running but on the exhaust side they do not run roller tip rockers.
Re: Top Fuel Hemi similar to OEM Hemi? [Re: RV2] #690767
05/07/10 01:02 PM
05/07/10 01:02 PM
Cincinnati, Ohio
Cincinnati, Ohio
That's correct, they have to be really strong to open the valves with nitro. And do you know what would happen if the rocker"broke off"?
Re: Top Fuel Hemi similar to OEM Hemi? [Re: Challenger 1] #690768
05/07/10 01:04 PM
05/07/10 01:04 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
KABOOM!!!!!!
Re: Top Fuel Hemi similar to OEM Hemi? [Re: Challenger 1] #690769
05/07/10 01:52 PM
05/07/10 01:52 PM
(Central) PA
Runner2go Offline
Runner2go  Offline
(Central) PA
So how many beers do they put in the gray cooler before heading into battle
1966 383, 4-sp Charger 38yrs
1970 440+6, 4-sp Road Runner 36yrs
1974 360, auto Challenger 25yrs,in Family 41yrs
2003 Ram 2500 QCLB 4x4 Cummins HO
2010 5.7L R/T 6sp Challenger - Mopar10
2018 392 Daytona Charger
Re: Top Fuel Hemi similar to OEM Hemi? [Re: Runner2go] #690770
05/07/10 03:39 PM
05/07/10 03:39 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I have a gun drilled crank bolt on my street Hemi that came from a top fuel car!
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Top Fuel Hemi similar to OEM Hemi? [Re: HemiRick] #690771
05/07/10 04:23 PM
05/07/10 04:23 PM
Cincinnati, Ohio
Cincinnati, Ohio
Me too, the reason it's drilled is so the socket will stay on the bolt. I put one on my 440.
Here's what the socket looks like. It's old school really. Nowadays we use a PSI reinforcement down there on the crank with a titanimun hub so it won't weld to the crank. Like in my picture above.
Re: Top Fuel Hemi similar to OEM Hemi? [Re: 4boxers4] #690772
05/07/10 04:31 PM
05/07/10 04:31 PM
Heart of Ohio
4boxers4 Offline OP
4boxers4  Offline OP
Heart of Ohio
My buddy is a Furd fan! I am smack talkin' for fun but I had heard enough of "the new Mustang beats the hemi Challenger" blah, blah...
And the old Hemi isn't related to the Top Fuel at all...blah, blah! Thanks guys!
Re: Top Fuel Hemi similar to OEM Hemi? [Re: Runner2go] #690773
05/07/10 04:34 PM
05/07/10 04:34 PM
Cincinnati, Ohio
Cincinnati, Ohio
I'm thinking about 10-12
Re: Top Fuel Hemi similar to OEM Hemi? [Re: Challenger 1] #690774
05/07/10 09:43 PM
05/07/10 09:43 PM
SW CO
HemiSportFury Offline
SW CO
The Donovan 417 as I recall was pretty much a copy of the 392 Hemi and many or most of the parts would interchange. They ran that engine for quite a few years after the 426 Hemi came out before the top fuel cars switched to the 426 derived motor.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: Top Fuel Hemi similar to OEM Hemi? [Re: HemiSportFury] #690775
05/08/10 12:37 AM
05/08/10 12:37 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
many of the external will fit they use a bigger lifter and a differnt cam bearing(size) most of the blower intakes are 10 bolt as compared to 16 bolt
pic of angies 426 (stock bore/stroke)hemi
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
