NHRA Stocker 64 Max Wedge #689582
05/05/10 03:26 PM
05/05/10 03:26 PM
Texas
dannysbee Offline OP
Texas
What class would a 64 Savoy with 415 hp engine, auto and steel front end fit into? Has anyone tried any of the latest Max Wedge Head offerings from Mopar performance? What other cars would you be competeing with?
Getting old just means you were smarter than some and luckier than others.
Re: NHRA Stocker 64 Max Wedge [Re: dannysbee] #689583
05/05/10 08:37 PM
05/05/10 08:37 PM
That car fits B/SA IF NHRA has not factored the HP on that combination, it might be able to fit C/SA by adding weight, maybe not Check with NHRA tech to find out there rae a lot of different brand cars with different motor combinations that can run B and C/SA. Your best bet for accurate information on this subject is with NHRA and on line at classracer.com
Re: NHRA Stocker 64 Max Wedge [Re: Cab_Burge] #689584
05/05/10 09:55 PM
05/05/10 09:55 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Looks like a natural A/SA to me. Drop to B/SA with weight. See the attached classification guide.
5966351-1964PLY[1].xls (207 downloads)
Floyd Lippencott IV
Re: NHRA Stocker 64 Max Wedge [Re: mr_340] #689585
05/05/10 10:16 PM
05/05/10 10:16 PM
wilson nc
jpm1916 Offline
jpm1916  Offline
wilson nc
64 Max Wedge 415 can run aa/sa,a/sa or b/sa
the 415 is rated @ 410 hp in IHRA
Re: NHRA Stocker 64 Max Wedge [Re: jpm1916] #689586
05/05/10 11:13 PM
05/05/10 11:13 PM
Texas
Texas
Looks like 135# would put it at the top of B/SA.
Re: NHRA Stocker 64 Max Wedge [Re: dannysbee] #689587
05/06/10 12:49 AM
05/06/10 12:49 AM
Oops, it is a Savoy, not a Fury or Sport Fury Sorry for the inacuraties(SP?)
383man [Re: Cab_Burge] #689588
05/06/10 12:58 AM
05/06/10 12:58 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This Max Wedge steel nose 64 Plymouth ran B/SA and could have run A/SA with some weight removed. What I dont know is the rules when it has the aluminum nose and scoop ?? Seems most in Stock are steel nose no scoop cars. I believe they built 145 Max Wedge 64 Plymouth's and about 100 were aluminum nose cars so I thought most would run the scoop. Or does it have to have the aluminum front end to use the scoop ?? Ron
Re: 383man [Re: 383man] #689589
05/06/10 01:09 AM
05/06/10 01:09 AM
Ron, to be NHRA legal you have to have the aluminum front end to run the aluminum hood with the aluminum scoop, at least the last time I heard anyways. That can be changed on a whim from NHRA
Re: 383man [Re: Cab_Burge] #689590
05/06/10 06:51 AM
05/06/10 06:51 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
You'll want to stay out of A/SA because of all the new Mustangs and Challengers that are not factored right. They are way fast and in a heads up race it would be tough to outrun them.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: 383man [Re: Jacob Pitt] #689591
05/06/10 06:59 AM
05/06/10 06:59 AM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
I believe the top cars in B/SA are running very low tens right now (10.08 or so). Some have gone faster. There are a bunch that run in the 10.30-10.40 range. It will cost huge money or huge time...probably both to build a competative car. Then you get torn down for running a good number. IMO build it the way you want and run it in Nostalgia Super Stock. The money is close to the same with no tear downs. Good luck. 64 Savoys are my favorite of all time. As Jerry Stein says, "Wedge em out!"
Re: 383man [Re: Tommy D] #689592
05/06/10 07:57 AM
05/06/10 07:57 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Lately anything in the upper classes of stock with a carb has been served for lunch. A 383 would be a much better choice.
Re: NHRA Stocker 64 Max Wedge [Re: dannysbee] #689593
05/06/10 09:15 AM
05/06/10 09:15 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
If you have the car a 426 Street Wedge is a decent package. As stated above AA, A, & B are real Hornet nests right now. The late MP 518 heads are not real good. They need a lot of work to get them to work. Better pff finding the hens teeth that are the real McCoy. One more note the Stage 3 intake is better than the early ones too. More Hens teeth to find.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 383man [Re: 383man] #689594
05/06/10 11:33 AM
05/06/10 11:33 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
The last time I saw a complete aluminum nose for a 1964 Plymouth (fenders, hood and scoop to make it legal for Stock or SS), the price was about $20k. NHRA should look at equivalent weight replacement fiberglass parts as a cost savings for racers. Or, at least allow a fiberglass hood and scoop and make them run steel fenders. It appears to me that NHRA doesn't want anyone to run the light weight package.
I'd try to contact John Shaul in NY about that combo. I think he's the fastest MW car out there in Stock. He did a set of carbs that I bought from Bogner several years ago.
Floyd Lippencott IV
383man [Re: mr_340] #689595
05/06/10 12:45 PM
05/06/10 12:45 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I believe this car was originally built by John Shaul as it is owned by Danny Jones right now and my brother drives it. It runs in the 10.40 to 10.70 area running B/SA. I would think NHRA would let them at least run a glass scoop since no one make an aluminum one. I have seen 63 and 64 Max Wedge cars dip in the 9's now and then on good tracks on good days. I believe John Shaul has run 9.70's with his 64 AA/SA car. They look so much cooler with the scoop also. Ron
Re: 383man [Re: 383man] #689596
05/06/10 01:00 PM
05/06/10 01:00 PM
Texas
Texas
You can buy the scoop in aluminum or steel but it is a all or none deal with NHRA. To run the scoop you have to run the aluminum fenders and hood.
Re: 383man [Re: dannysbee] #689597
05/06/10 02:26 PM
05/06/10 02:26 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Can run a scoop only with single 4bbl Nascar Hemi and only the steel front.
The little old lady from Pasadena is back!
Re: 383man [Re: Barnstorm] #689598
05/06/10 05:42 PM
05/06/10 05:42 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I may be wrong but I think the scooped alum front end is a super stock designated item only. Not legal for stock. I believe the package was only available with 425 hp.
JAKES AUTOMOTIVE
383man [Re: JAKE68] #689599
05/06/10 06:12 PM
05/06/10 06:12 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I believe thats definetly right for 63. I know Plymouth built 1196 Max Wedge cars in 63 and only 40 were the aluminum front end cars. And as you said they were all 425 hp engines and in the Savoy only from what I remember. Now in 64 only 245 Plymoth Max Wedge and Hemi cars were built. I believe it was 155 Maxie cars and 90 Hemi cars. Dont remember how many were aluminum cars. Ron
Re: 383man [Re: JAKE68] #689600
05/08/10 12:00 PM
05/08/10 12:00 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Look at the classification guide I posted near the top. The aluminum nose and scoop is legal for Stock (and SS). You would have to run the high compression MW and the factor is 7.61 to put a Savoy in AA/SA, or add weight to drop to A/SA. The factor with the LC MW is 8.18 with steel nose and flat hood. Natural A/SA car, move up or down a class.
Floyd Lippencott IV
Re: 383man [Re: mr_340] #689601
05/08/10 01:24 PM
05/08/10 01:24 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Seeing that the price of aluminum has went up so much I thought you should know what AMD is up to..
http://www.autometaldirect.com/
It's time we lobby AMD!
