Need help identifying rockers #689053
05/05/10 04:18 AM
05/05/10 04:18 AM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
I've seen these advertised as Crane - but I don't think they are.
They are steel and seem to be of pretty good quality - I'm wondering Comp?
I'd appreciate knowing as Im not fitting them if they are a rubbish make.
They feature:
Oval scooped top side with an H stamped in the front of the "scoop"
An almost straight arm (this rules out the Pro Comp rockers)
A brass(?) pressed fit roller pin
Re: Need help identifying rockers [Re: Moparmal] #689054
05/05/10 09:03 AM
05/05/10 09:03 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
They look like the comp magnums before the pro mag came out I think the part #1420.
Re: Need help identifying rockers [Re: Scamp408] #689055
05/06/10 04:05 AM
05/06/10 04:05 AM
Moparmal Offline OP
Moparmal  Offline OP
Ok thanks Scamp408 - That matches with what someone else I spoke with thinks as well.
Cheers and thanks for your input.
Re: Need help identifying rockers [Re: Moparmal] #689056
05/06/10 06:20 AM
05/06/10 06:20 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yea they look like small block
