I've seen these advertised as Crane - but I don't think they are.
They are steel and seem to be of pretty good quality - I'm wondering Comp?
I'd appreciate knowing as Im not fitting them if they are a rubbish make.
They feature:
Oval scooped top side with an H stamped in the front of the "scoop"
An almost straight arm (this rules out the Pro Comp rockers)
A brass(?) pressed fit roller pin
