Re: Black Wrinkle Cast Aluminum Valve Covers
[Re: wingman]
#68908
06/06/08 11:09 PM
06/06/08 11:09 PM
Posts: 3,374 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
1. Make sure you get the grommets designed for cast valve covers--not steel ones. they are thicker.
2. Machine out the holes instead of "punching" them out if you can. They seal better that way.
3. I drilled out the center of one of the passenger side filler cap and put a barbed fitting with a nut on the back to hold the cap together. this allowed me to use the breather hose in a somewhat stock location.
4. Ignore the extra chrome breather--I put that in for fun. If you want to keep the stock configuration, just don't drill that one out.
Hope this helps
P.S. It's a 440--I just keep the 383 pie pan for fun.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
