Re: R3 low deck ???? [Re: RyanJ] #688811
05/05/10 03:24 PM
05/05/10 03:24 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
with a modified MP 9.20" M1 W2 intake manifold.
did that intake ever exist????
Re: R3 low deck ???? [Re: SB449VALIANT] #688812
05/05/10 03:46 PM
05/05/10 03:46 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I see your point, thanks RJ
Re: R3 low deck ???? [Re: emarine01] #688813
05/05/10 08:09 PM
05/05/10 08:09 PM
St. Louis Mo.
10 o to go Offline OP
"Happy Don"
"Happy Don"
St. Louis Mo.
Thanks guys .Now my head is spinning .
So if i get the number off the block will that help me with deciding .Who knows maybe its a 48 degree block .The guy says he has B1BS heads from another S.B .B1BA is the right head .
$1500 for the block ,so i need to check it out .
Where can I get all the info for R3 blocks I tried the tech area.
So even with the cam ,pushrod on a 59 degree where does the rpm ,cam have the issue ? Most of us are running the 340 360s stroked with eddy heads .
thanks Don
Don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: R3 low deck ???? [Re: SB449VALIANT] #688814
05/05/10 09:05 PM
05/05/10 09:05 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Well if I used one, it must exist....
Actually a pretty nice intake... wish the tall deck was like it in the runner/plenum area.
That motor I did was a small inch W2 deal for some type of dragster thing.... 365 inch. Did'nt dyno it... dunno what it makes for power.
Re: R3 low deck ???? [Re: RyanJ] #688815
05/05/10 10:35 PM
05/05/10 10:35 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
http://www.jimsautoparts.com/mopar_performance_blocks.htm
Look here for part numbers and specifications.
The numbers have changed over the years too I believe.........early blocks don't have the AC in the P/N and also do not have the lifter bores drilled on the 48 degree blocks.
I think the 59 degree lifter bores intersect with the oil galleys and do not need to be drilled.....and the later R 3's are drilled by the factory.
Edited to add ......... I think these are the early part numbers listed .
The later blocks are followed by AC ... I think.
But this might be of some help.
Re: R3 low deck ???? [Re: tubtar] #688816
05/05/10 11:36 PM
05/05/10 11:36 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Check Bouchillion
http://www.bpemopar.com/SMALL_BLOCK.htm
Their catalog seems to be close to current......I don't know who has what in stock for these blocks either.
But they seem to have the latest block P/N's
I went looking for the drill fixture to drill the lifter bores.......it is discontinued , but these guys had I think 9 of them in stock.
A lot of stuff from MoPar is getting tough to track down.
Re: R3 low deck ???? [Re: tubtar] #688817
05/06/10 11:17 PM
05/06/10 11:17 PM
San Angelo Tx
Alan Warman Offline
Alan Warman  Offline
San Angelo Tx
Well I just happen to have a good 9.20 block and two short deck W2 intakes. Will be putting a add in parts for sell this weekend. Also will trade 9.20 block for a 360 race block. Need it for our superstock car.
Thanks Alan
Alan Warman STK 4107
Re: R3 low deck ???? [Re: Alan Warman] #688818
05/06/10 11:30 PM
05/06/10 11:30 PM
408Dust Offline
408Dust  Offline
Alan you have a PM...
Re: R3 low deck ???? [Re: 10 o to go] #688819
05/06/10 11:47 PM
05/06/10 11:47 PM
ill
dennismopar73 Offline
ill
hi don
i think you have pretty nice piece now
imo lose some wieght off the nose of car
rack pinnion,(easy 100# loss!) we have said it before
make the firewall straight so as to get to trans bolts easy (not move motor bsck)
then make new step 1 7/8 to 2" header
jmo with all else you have i think 9.70? high 9.60s
not out of question
scopeout:
Re: R3 low deck ???? [Re: 10 o to go] #688820
05/06/10 11:55 PM
05/06/10 11:55 PM
ill
ill
lets see 170$ rack
100$ for metal tubing
cut out inner fenders
remove old firewall put new straight one in
get trans bolts out easy =priceless
new headers 400.00
total around 1000-1200$$
pickup in et
2-3 tenths mmm
Re: R3 low deck ???? [Re: 10 o to go] #688821
05/07/10 06:43 AM
05/07/10 06:43 AM
St. Louis Mo.
"Happy Don"
"Happy Don"
St. Louis Mo.
Dennis thought you were going to say big block .
Re: R3 low deck ???? [Re: 10 o to go] #688822
05/07/10 10:43 PM
05/07/10 10:43 PM
ill
ill
nope wouldnt i know how much you likem
so do i
im just set to run big blocks
small block in the 'TWISTED 'mmm
someday???
