How much is too much? #688572
05/04/10 09:14 PM
05/04/10 09:14 PM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
Oil pressure. 15/40 Delo. Cold start it's over 100psi. After warmup 75-80. All at idle. Thru the traps at 6400 rpm, waaaay over 100 psi. Thx
Re: How much is too much? [Re: clyde] #688573
05/04/10 09:21 PM
05/04/10 09:21 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
That's too much.
Go back to a std volume pump, and/or put thinner oil in.
Re: How much is too much? [Re: dave571] #688574
05/04/10 09:31 PM
05/04/10 09:31 PM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
Standard off the shelf advance auto replacement pump. Anybody make a softer by-pass spring?
Re: How much is too much? [Re: clyde] #688575
05/04/10 11:30 PM
05/04/10 11:30 PM
Cab_Burge Online work
Cab_Burge  Online Work
That doesn't sound right Sounds like they sold you a high volume or high pressure pump and said it was a standad pump you can cut one coil off of the spring, especially if it is the black spring. I'm assuming this is a BB and not a SB Mopar, either way the pressure is to high and you can trim either spring to reduce pressure if you can find a spring that will reduce the pressure. I trim almost all of the new springs on the high volume pumps I use, I like to have 10 lbs per 1000 RPM, or 70 lbs at 7000 RPM I do break the motor in with 5W20WT oil and wait until the oil is hot before starting the trimming process, rev it up and read the oil pressure and go from there
Re: How much is too much? [Re: Cab_Burge] #688576
05/04/10 11:39 PM
05/04/10 11:39 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Good advice!!
Re: How much is too much? [Re: Cab_Burge] #688577
05/04/10 11:44 PM
05/04/10 11:44 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I have an all alum Indy motor, with there oil pump and spray bar oiling and it has the same kind of oil pressure your dad has. The guys at indy say that is how it should be. They did not biuld the motor.
Re: How much is too much? [Re: Darryls-Demon] #688578
05/05/10 12:26 AM
05/05/10 12:26 AM
S.W. Ohio
clyde Offline OP
clyde  Offline OP
S.W. Ohio
Yea it's a 440. I actually pulled the spring out of a 383 that had "normal" pressure and put in this pump but, made no difference in pressure. I'll try the trimming routine and see if that helps. THX
Re: How much is too much? [Re: clyde] #688579
05/05/10 12:29 AM
05/05/10 12:29 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Sounds like the relief valve is stuck.
Kevin
Re: How much is too much? [Re: clyde] #688580
05/05/10 05:54 AM
05/05/10 05:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I put a thicker washer in my by-pass to up the pressure
due to a error in my build(forgot the plug in the front
oil galley) and when I figured out what the problem
was and corrected that , I forgot to pull that washer
out and when I rev'd it the pressure went to 140 and
blew the oil filter apart.... so watch out for that high
pressure...... also it takes more HP away from your
engine to spin the pump with all that pressure
This was on a BB
Re: How much is too much? [Re: Twostick] #688581
05/05/10 10:36 AM
05/05/10 10:36 AM
dave571 Offline
dave571  Offline
Kevin
try a different pump
Re: How much is too much? [Re: MR_P_BODY] #688582
05/09/10 03:24 AM
05/09/10 03:24 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
This was on a BB
Buddy of mine did exactly the same thing years ago.
It blew a brand new Lee Eliminator filter across the shop with 8 quarts of Kendall racing 50 right behind it.
Kevin
