questions for painters?? #688525
05/04/10 08:00 PM
05/04/10 08:00 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
What type of sander should I use to strip paint to bare metal. I have a Ram with alligator skin textured OEM paint on the roof and hood (spider webbing gone crazy). Needs to come all the way off without harming the metal.
On the repaint, how much time should be allowed between the base color coat and the clear coat?
Thanks!
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: questions for painters?? [Re: GO_Fish] #688526
05/04/10 08:12 PM
05/04/10 08:12 PM
Kirkland, Washington
Pacnorthcuda Offline
Use a DA with 5 or 6 inch PSA (pressure sensitive adhesive) disks. 80 grit works well (sanding scratches in the metal are good--primer will fill).
Most base-clears have a 24 hour window to clear. Check your data sheets for YOUR paint.
Re: questions for painters?? [Re: Pacnorthcuda] #688527
05/04/10 08:17 PM
05/04/10 08:17 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I use the 3M paint stripping discs and a drill to take paint down to bare metal.
Re: questions for painters?? [Re: Neil] #688528
05/04/10 08:38 PM
05/04/10 08:38 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
first thing to do is get some razor blades and a scraper and scrape off what you can then sand off the rest or you will spend a small fortune in sand paper and time. If you do it right you wont goudge up the metal.
Re: questions for painters?? [Re: magiccuda] #688529
05/04/10 08:53 PM
05/04/10 08:53 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
compressed air and duct tape works too.
Re: questions for painters?? [Re: stinger] #688530
05/04/10 09:38 PM
05/04/10 09:38 PM
Lafayette,Tennessee
69runner Offline
69runner  Offline
Lafayette,Tennessee
aircraft stripper. it is a lot quicker then sanding everything.
Re: questions for painters?? [Re: 69runner] #688531
05/04/10 09:44 PM
05/04/10 09:44 PM
Jacksonville Florida
elitecustombody Offline
Stripper can be bought at most auto parts stores and even Wal-Mart, brush it on in one direction,throw some trash bags or plastic sheeting for about 20- minutes,scrape,brush,rinse off, sand off the rest with 80 grit on cheap D/A sander, the palm sanders don't work as quick .
Good luck
Re: questions for painters?? [Re: GO_Fish] #688532
05/04/10 09:51 PM
05/04/10 09:51 PM
crlush Offline
crlush  Offline
If you are going to buy a sander, I have a hog sander, its like a da but its sanding disk is geared so when you press on it while your sanding the pad will keep spinning, (it doesnt spin fast like a disk grinder so you wont grind into metal, but it removes bondo and paint pretty fast. ingersoll rand makes a pretty good one.
http://cgi.ebay.com/ebaymotors/Ingersoll...=item53e03f662f
