70 Bee wiring harness HELP #688227
05/04/10 01:52 PM
05/04/10 01:52 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
I know all about extra post,but I'm just looking 4 as much info./help as I can.....
I was on the final screw install and bumped the headlight delay relay and poof the wiring starts to smoke.....I pull the wires off ASAP and burned the %&^%^#$@ on my fingers.NOW WHAT DO I DO !!!! remove the harness,replace the harness,remove the dash....This is a survivor car and I've been so careful with everything else I've done now this...I'm so mad and pissed off I can't see straight,or think straight..What would you do..Remove the cluster,or the harness and would you repair the wiring or replace it...The other thing that is a factor is I lost my job (Like so many of us here.) So that is my situation.
Thanks in advance for your help here......
Re: 70 Bee wiring harness HELP [Re: Hemiruss] #688228
05/04/10 01:59 PM
05/04/10 01:59 PM
St Charles MO
70Coronet500Vert Offline
St Charles MO
Since you have time on your hands (unfortunately) you can remove the harness and try & determine where two wires shorted or where one wire contacted ground. Short circuit can only be one of those two items.
I am assuming your under dash harness smoked and not the underhood?
Just carefully trace it back and look for the damage.
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 70 Bee wiring harness HELP [Re: 70Coronet500Vert] #688229
05/04/10 07:50 PM
05/04/10 07:50 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
Yea I'm going to pull the cluster and check the damage.I was trying to get it ready for the show in Tampa,and the worse part is I did it by hitting the relay with my arm.....It just makes me so mad......BUT you got to love it or sell it..
