Page 2 of 5 1 2 3 4 5
Re: Tear down has begun [Re: dennismopar73] #688130
05/04/10 06:34 PM
05/04/10 06:34 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
these things happen, Only thing i dont like, that oil pan seems like it has almost no baffling to keep the oil in the sump, Id put an external pickup on there if for nothing else but to get a good solidly welded baffle on there to keep oil in the sump under accleration.
Only a sugestion as im sure Scott knows a lot more than me...LOL
....BAD A$$ STREET CAR.....
Re: Tear down has begun [Re: n20mstr] #688131
05/04/10 07:10 PM
05/04/10 07:10 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Stock block, stock crank, stock main caps/bolts, old valve springs, stock oiling system...7700RPM..
looks like normal expectations to me. I don't want or mean to cause any anger,,but if you are going to run stock parts,,stay in the 6000 RPM area. I didn't really want to comment on this,,but I have watched your engine build thread and wondered just how it would turn out. I hoped it would be GREAT as I would possibly follow your foot steps ,,
If you like drag racing, support your local track.
Re: Tear down has begun [Re: CHAPPER] #688132
05/04/10 07:19 PM
05/04/10 07:19 PM
PA
moparacer Offline
moparacer  Offline
PA
Looks bad but you are lucky it didn't decide to kick the #3 and #4 rods out in the traps the way they look. J.M.O. but I would throw the cam in the scrap pile too.
Did it throw any debris up behind the piston skirts and scuff up the cylinder walls?
Any time I ever had a mishap like that it did.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Tear down has begun [Re: Chris'sBarracuda] #688133
05/04/10 07:38 PM
05/04/10 07:38 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Sorta strange to float the exhaust valves, they are
lighter than the intakes... were these new springs?
But isn't the exhaust much closer and chasing the valve?
Chris..
The exhaust valves are the ones trying to get closed
before the piston catches them.
Intakes are opening as the piston travels downward on
the "intake stroke" and usually in closest proximity to
each other between 5º and 10º ATDC.
If a piston hits an intake valve, it was either assembled
wrong or something went VERY wrong.
I hope it's not too expensive Bill.
Re: Tear down has begun [Re: WILD BILL] #688134
05/04/10 07:58 PM
05/04/10 07:58 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
with the valve marks on the pistons will there be other signs of dammage on the pushrods,rockers,lifters,cam?i was looking at the oiling path and thinking if maybe it starved the oil somehow to the rod and the valve events maybe had something to do with it.it would take a lot for that to happin i think.
Re: Tear down has begun [Re: blownzoom440] #688135
05/04/10 08:31 PM
05/04/10 08:31 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Racing with old springs is a problem and might be why they kissed on some but not all. Also, it's a flat tappet... You can be bleeding oil out certain lifters if they are loose too.
Re: Tear down has begun [Re: blownzoom440] #688136
05/04/10 08:40 PM
05/04/10 08:40 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Curious to know what the #2 main bearing looked like? (missing in pic). Did it slip out of the tab and partially block the oil hole in the block? That rod would have gotten oil from #2 main. Oil hole in crank clear?
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Tear down has begun [Re: moper] #688137
05/04/10 08:53 PM
05/04/10 08:53 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
I think the 7700 rpms hurt it. Few friends run that 555 solid comp cam and about 6400 it's out of power for them. Think i would toss the stock main bolts and throw in some arp main bolts.
Hope you get her back together soon. Good luck!
Re: Tear down has begun [Re: Dads426] #688138
05/04/10 08:55 PM
05/04/10 08:55 PM
UK
602heavy Offline
602heavy  Offline
UK
#2 rod looks fine so thinking some debris got lodged in oil way from #2 main journal to #3 rod journal. .....................did #3 piston hit the head? , may of egged the rod journal causing the overheat issues.
Re: Tear down has begun [Re: 602heavy] #688139
05/04/10 09:15 PM
05/04/10 09:15 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Wow, worse than I thought it was going to be.
What side did the fuel come out of the header? The left??
Wish I still had my spare .613 Ultradyne for you to try
You have my # if you need me
Re: Tear down has begun [Re: 602heavy] #688140
05/04/10 09:15 PM
05/04/10 09:15 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
it's bad enough to mess thing's up for you but not messed up enough to ruin every thing, from the pic's crank look's fixable, the burn't rod's are toast and the cam is junk, at least it didn't trash the block, as far as the witness mark's on the piston's,, look's like some valve float from the over rev, and I have seen worse,,,let see 10 day's till Columbus and it's all in the shop,,,,,,you might be in the trailer hooking everything up while Dad is driving the motorhome down the interstate,,,but it can be done.
if you need anything,,then let me know.
Re: Tear down has begun [Re: dartman366] #688141
05/04/10 09:41 PM
05/04/10 09:41 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
I have a stock, 10 under forged crank in my 440.
Let me know if you need it.
Re: Tear down has begun [Re: WILD BILL] #688142
05/04/10 09:55 PM
05/04/10 09:55 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Sorry to see that, and it sucks too see all that cash go up in smoke for you. Atleast it didnt make an unexpended window, and wipe out the car going through the traps. I wish i had bi block parts cause Id help if i could.
Kasey
Re: Tear down has begun [Re: demon440] #688143
05/04/10 09:58 PM
05/04/10 09:58 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
Question....did you run Synthetic oil with Alky?? Have a friend that had one do the same thing. A very well know engine shop told us never run synthetic oil with our Alky. We have since changed to Valvoline VR-1 race oil with no problems since. His was running synthetic and only ran a short time. Did the SAME things yours did minus the valve float/piston problems.....
Re: Tear down has begun [Re: CHAPPER] #688144
05/04/10 10:09 PM
05/04/10 10:09 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Kaleno block... i dont understand using no studs though
Mopar Performance
Re: Tear down has begun [Re: DaKuda] #688145
05/04/10 10:21 PM
05/04/10 10:21 PM
ill
dennismopar73 Offline
ill
type of oil nothin to do with this
Re: Tear down has begun [Re: dennismopar73] #688146
05/04/10 10:42 PM
05/04/10 10:42 PM
Moparnut426 Offline
Moparnut426  Offline
I wouldnt laugh too hard, I have heard the same thing and NONE of my Dirt car buddies who run drunk engines run synthetic. They do however run Brad Penn which has some synthetic addiitives. They all have told me similar things dealing with fast wear issues.
Kasey
Re: Tear down has begun [Re: Moparnut426] #688147
05/04/10 10:50 PM
05/04/10 10:50 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Wow, what a roller coaster ride this has been! Cant believe this has happened, Bill. I hope Scott makes it all good for you...I think he should throw in a new cam and crank for you!
Re: Tear down has begun [Re: dennismopar73] #688148
05/04/10 10:56 PM
05/04/10 10:56 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
You have now shown your ignorance...
Re: Tear down has begun [Re: B1Fish540] #688149
05/04/10 11:22 PM
05/04/10 11:22 PM
MD
HEMI472 Online content
HEMI472  Online Content
MD
so whos going to pay for this????????????????
you or scott???????????
