Re: Tear down has begun
[Re: dennismopar73]
#688130
05/04/10 06:34 PM
05/04/10 06:34 PM
Posts: 4,682 On the parachute mount
n20mstr
these things happen, Only thing i dont like, that oil pan seems like it has almost no baffling to keep the oil in the sump, Id put an external pickup on there if for nothing else but to get a good solidly welded baffle on there to keep oil in the sump under accleration. Only a sugestion as im sure Scott knows a lot more than me...LOL
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#688131
05/04/10 07:10 PM
05/04/10 07:10 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Stock block, stock crank, stock main caps/bolts, old valve springs, stock oiling system...7700RPM.. looks like normal expectations to me. I don't want or mean to cause any anger,,but if you are going to run stock parts,,stay in the 6000 RPM area. I didn't really want to comment on this,,but I have watched your engine build thread and wondered just how it would turn out. I hoped it would be GREAT as I would possibly follow your foot steps ,,
If you like drag racing, support your local track.
[Re: CHAPPER]
#688132
05/04/10 07:19 PM
05/04/10 07:19 PM
Posts: 2,511 PA
moparacer
PA
Looks bad but you are lucky it didn't decide to kick the #3 and #4 rods out in the traps the way they look. J.M.O. but I would throw the cam in the scrap pile too.
Did it throw any debris up behind the piston skirts and scuff up the cylinder walls?
Any time I ever had a mishap like that it did.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Chris'sBarracuda]
#688133
05/04/10 07:38 PM
05/04/10 07:38 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Sorta strange to float the exhaust valves, they are lighter than the intakes... were these new springs?
But isn't the exhaust much closer and chasing the valve?
Chris..
The exhaust valves are the ones trying to get closed before the piston catches them.
Intakes are opening as the piston travels downward on the "intake stroke" and usually in closest proximity to each other between 5º and 10º ATDC.
If a piston hits an intake valve, it was either assembled wrong or something went VERY wrong.
I hope it's not too expensive Bill.
[Re: blownzoom440]
#688135
05/04/10 08:31 PM
05/04/10 08:31 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Racing with old springs is a problem and might be why they kissed on some but not all. Also, it's a flat tappet... You can be bleeding oil out certain lifters if they are loose too.
[Re: Dads426]
#688138
05/04/10 08:55 PM
05/04/10 08:55 PM
Posts: 1,200 UK
602heavy
UK
[Re: 602heavy]
#688139
05/04/10 09:15 PM
05/04/10 09:15 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Wow, worse than I thought it was going to be. What side did the fuel come out of the header? The left?? Wish I still had my spare .613 Ultradyne for you to try You have my # if you need me
[Re: 602heavy]
#688140
05/04/10 09:15 PM
05/04/10 09:15 PM
dartman366
Mt. Vernon, Ohio
it's bad enough to mess thing's up for you but not messed up enough to ruin every thing, from the pic's crank look's fixable, the burn't rod's are toast and the cam is junk, at least it didn't trash the block, as far as the witness mark's on the piston's,, look's like some valve float from the over rev, and I have seen worse,,,let see 10 day's till Columbus and it's all in the shop,,,,,,you might be in the trailer hooking everything up while Dad is driving the motorhome down the interstate,,,but it can be done. if you need anything,,then let me know.
[Re: CHAPPER]
#688144
05/04/10 10:09 PM
05/04/10 10:09 PM
Posts: 6,295 U.S.
moparniac
U.S.
Kaleno block... i dont understand using no studs though
Mopar Performance
[Re: dennismopar73]
#688146
05/04/10 10:42 PM
05/04/10 10:42 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
type of oil nothin to do with this
I wouldnt laugh too hard, I have heard the same thing and NONE of my Dirt car buddies who run drunk engines run synthetic. They do however run Brad Penn which has some synthetic addiitives. They all have told me similar things dealing with fast wear issues.
Kasey
[Re: dennismopar73]
#688148
05/04/10 10:56 PM
05/04/10 10:56 PM
Posts: 1,015 Down South
DaKuda
Down South
You have now shown your ignorance...
[Re: B1Fish540]
#688149
05/04/10 11:22 PM
05/04/10 11:22 PM
Posts: 781 MD
HEMI472
MD
Wow, what a roller coaster ride this has been! Cant believe this has happened, Bill. I hope Scott makes it all good for you...I think he should throw in a new cam and crank for you!
so whos going to pay for this????????????????
you or scott???????????
