64 B-body torsion bars #688084
05/04/10 12:27 PM
05/04/10 12:27 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
Hi- is there just one position to install the torsion bars? I ask because mine are uneven and I’m trying to figure out if they are just fatigued or in wrong.
The driver’s side has the adjuster all the way maxed out, and the passenger side if maxed out makes the ride height about 1.5 inches higher on that side. So I have the passenger side wound way down to match the ride height.
Seem strange?
Thanks!!
Re: 64 B-body torsion bars [Re: HitIt] #688085
05/04/10 12:58 PM
05/04/10 12:58 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Sounds like tired bars to me. Mine droops too.
Time for new ones.
- Stu Harmon
Re: 64 B-body torsion bars [Re: feets] #688086
05/04/10 02:36 PM
05/04/10 02:36 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
I figured they were tired too. I want to get my front end nice and high, as in old school superstock style. What's a good bar diameter to go with? Car has a 440 in it.
Re: 64 B-body torsion bars [Re: HitIt] #688087
05/04/10 02:53 PM
05/04/10 02:53 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
That or the bar is in the wrong hex.Ive seen it and did it once on one of my Imperials.Pretty much T bars dont wear out.The snap but dont wear as rears do.Rocky
Chrysler Firepower
Re: 64 B-body torsion bars [Re: therocks] #688088
05/04/10 03:06 PM
05/04/10 03:06 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
How can I tell if it's in the wrong hex? Thanks for the help.
Re: 64 B-body torsion bars [Re: therocks] #688089
05/04/10 03:17 PM
05/04/10 03:17 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
T-bars do wear out. I can crank mine up a couple inches and it'll settle back down after a little driving. The bolt doesn't back out.
The front of the hot rod sits level right now. The adjuster on the right side sticks out past the control arm. The driver's side is up inside the arm.
- Stu Harmon
Re: 64 B-body torsion bars [Re: feets] #688090
05/04/10 04:41 PM
05/04/10 04:41 PM
CONNECTICUT
RoyceFlo73 Offline
RoyceFlo73  Offline
CONNECTICUT
T-bars absolutely do wear out. They wear pretty slowly, esp. compared to coils. But get a nick, scuffs, or some rust on the T-bar and they will actually wear rather quickly. T-bars are springs and the point of failure and rate of wear can be calculated.
As far as which springs to use, just like anything, you have to figure what you're using it for an consider the rest of your setup.
Re: 64 B-body torsion bars [Re: therocks] #688091
05/04/10 04:43 PM
05/04/10 04:43 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
That was my first thought.
Scott
1969 Super Bee, 383/4 speed
Re: 64 B-body torsion bars [Re: StukaJU87] #688092
05/04/10 05:14 PM
05/04/10 05:14 PM
Ohio
V
viperakron Offline
viperakron  Offline
V
Ohio
If you have SS Springs you are going to have to put several more turns in the LR bar to even the cars attitude.
Re: 64 B-body torsion bars [Re: StukaJU87] #688093
05/04/10 06:29 PM
05/04/10 06:29 PM
Santa Barbara, CA
HitIt Offline OP
HitIt  Offline OP
Santa Barbara, CA
how do i tell? ill snap a pic tonight if that helps. thanks.
