Late model starter in 1971 Plymouth B-body #686761
05/02/10 07:16 PM
05/02/10 07:16 PM
Tyler, TX
LandShark Offline OP
Tyler, TX
Over the weekend, I installed a 1997 magnum truck engine (360). The truck engine came with the factory starter. The mounting section looked so similar to the 71 unit except 1/3 the weight and mass that I was optimistic that it would install. An hour later, hope was lost and the factory 71 unit bolted right up. I am having clearance issues with the 71 unit and headers. Can anyone tell me if this unit should work? Attempts at bolting it up seem to say no, but I would like confirmation. Also, if it doesn't work, is there a budget starter out there that is small and can bolt onto this combo? I am running a 1971 904 tranny with balancing weights welding onto the converter behind a 1997 Ram 1500 magnum motor... Many Thanks!
Re: Late model starter in 1971 Plymouth B-body [Re: LandShark] #686762
05/02/10 07:51 PM
05/02/10 07:51 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
What is hitting or not lineing up?
I have a 92 full size van starter on the wifes 72 charger
Re: Late model starter in 1971 Plymouth B-body [Re: LandShark] #686763
05/02/10 08:42 PM
05/02/10 08:42 PM
scratchnfotraction Offline
some of the mini starters have a plastic wire adaptor/extention piece that you remove and hook the wire to the other 2 studs from the starter
this helps clearance problems at the block/starter
the newer starters are a fairly common upgrade now days
i have it on a sb 318 and one on the 440 engine,I also use the mini alt on the 440 with stock alt brackets from the non a/c 440 engine
the mini starter usally has a lot of header room and can be R&R with out to much hassles of R&R the header
what exactly did not work for you on the mini starter??
that extention piece is the only thing I have ever seen that needed removed...then its a bolt on deal
some of the later ones have a diff hook up on the small wire but a plug from a JY truck can be spliced..have that on the 318 truck
Re: Late model starter in 1971 Plymouth B-body [Re: scratchnfotraction] #686764
05/04/10 02:07 AM
05/04/10 02:07 AM
Tyler, TX
Tyler, TX
Thanks for all the info... The 3am time frame was the main cause of failure...
Re: Late model starter in 1971 Plymouth B-body [Re: LandShark] #686765
05/04/10 03:15 AM
05/04/10 03:15 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I went to the Fall Fling in Van Nuys CA last year and bought a pair of Doug Thorley headers at the swap meet for $25. SCORE ! My Duster 340 had manifolds, so this seemed ideal. The right side went in easily and look very similar to TTI in the routing of the tubes. The left side was a real pisser. I had it in and out of the car 15 times trying to get proper clearance. The mini starter solenoid was on the very bottom of the starter and required crushing of the tops of two tubes for clearance. I had to smash them almost in half . NOT GOOD. I ordered a new starter from Mancini, but despite what the salesman said, the solenoid was in the EXACT SAME SPOT as the mini starter. The stock starter would fit, but the electrical leads would have been too close to 3 of the tubes, so I cut the left side out with a sawzall and ordered TTI pipes. I have since read about some starter that allows the starter body to be clocked for added clearance. I wish I had checked Moparts before I started denting the Doug pipes.
Re: Late model starter in 1971 Plymouth B-body [Re: WILD BILL] #686766
05/04/10 07:41 AM
05/04/10 07:41 AM
IL
71383beep Offline
71383beep  Offline
IL
Yeah I did the same thing based on advice I got from a local mopar guru. Just use a regular starter from a dakota or even a minivan and it should bolt up after removing the wiring adaptor on the solenoid. Been running one for many years now without an issue. 383 w/ TTI 1 7/8" headers.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Late model starter in 1971 Plymouth B-body [Re: Kern Dog] #686767
05/04/10 07:39 PM
05/04/10 07:39 PM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
Is this the starter? It will clear without modifying the headers and with more clearance than the old stock starter:
http://www.robbmcperformance.com/products/mopar_starter.html
http://www.robbmcperformance.com/products/starter_home.html#comparison
Re: Late model starter in 1971 Plymouth B-body [Re: RobbMc] #686768
05/04/10 09:48 PM
05/04/10 09:48 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
