Honest opinion. Holley DP or Carter #686348
05/02/10 09:51 AM
05/02/10 09:51 AM
Dalton, MA
Slipknot440 Offline OP
Dalton, MA
Looking for a new carb for my road runner (specs below, m1 intake single 4). I'm never going to competitively drag race it, but I will drive it like i stole it around town, but also have a 2 year old that I don't need to be standing on the side of the road with if it vapor locks or has any other problems. So my question is do I go for more performance with the Holley DP 750, or do I go with the old reliable Carter 750. I currently have an Eddy 800 that I don't like very much on it (good at high rpm, not all that great around town driving)
Re: Honest opinion. Holley DP or Carter [Re: Slipknot440] #686349
05/02/10 10:09 AM
05/02/10 10:09 AM
Sturgis S.D.
tripleblackcuda Offline
Sturgis S.D.
I like Holleys the best, just seem to be easier to work on, plus, usually most parts stores have parts for them on hand.
Re: Honest opinion. Holley DP or Carter [Re: Slipknot440] #686350
05/02/10 10:15 AM
05/02/10 10:15 AM
SK. Canada
Not_A_Duster Offline
SK. Canada
I prefer holleys, but if it's for a street driven car, I would use a vaccum secondary model like the 3310 or even a street avenger rather than the double pumper. You give up a little straight line performance, but it'll be much better mannered on the street.
....evil is winning....
Re: Honest opinion. Holley DP or Carter [Re: Not_A_Duster] #686351
05/02/10 10:49 AM
05/02/10 10:49 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Hemi RR? Your existing carb may just need some tuning on the needles & springs if you have low vacuum. If you have an AT, a Holley vacuum secondary may need some tuning on the secondary diaphragm to accelerate properly, and a DP (I'd be thinking 850 CFM) will likely need some tuning on the pump shots. Different systems that accomplish the same goal. Changing to a Holley will of course require different fuel plumbing. Need more info on your car to make a better recommendation.
Re: Honest opinion. Holley DP or Carter [Re: Slipknot440] #686352
05/02/10 10:59 AM
05/02/10 10:59 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If you stay w/ an eddy I wouldn't go down to the 750. Your 800 thunder should be workable. That said a holley is a way better carb w/ more tunability (is that even a word). Anyway a 750HP would be my choice.
Coming soon!!!!
Re: Honest opinion. Holley DP or Carter [Re: Mr.Yuck] #686353
05/02/10 11:06 AM
05/02/10 11:06 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
It's very hard to beat the good old Holley 3310 in 780 or 750 CFM. Just run it as is and do some minor jet changes after a good cycle on the plugs.I still think plug reading is the best way to tune your jetting.
Gus
64 Plymouth Savoy
Dana 60
Re: Honest opinion. Holley DP or Carter [Re: fourgearsavoy] #686354
05/02/10 12:53 PM
05/02/10 12:53 PM
Dalton, MA
Dalton, MA
do I need to change the linkage (auto) or buy an adapter. I've never had a holley on any of my mopars, actually this is my first eddy too.
Re: Honest opinion. Holley DP or Carter [Re: Slipknot440] #686355
05/02/10 01:50 PM
05/02/10 01:50 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
An 800 AVS should be terrific on that car. You would be better off spending a bit of money having an expert tune it for you rather than buying a new carb that will also need tweaking. If you must though, I would try an 850 double pumper on it (you'll still have to tweak the jets and PV IMO).
Sheldon
Re: Honest opinion. Holley DP or Carter [Re: Slipknot440] #686356
05/02/10 04:59 PM
05/02/10 04:59 PM
Rittman Ohio
Rittman Ohio
You can get the lever adapter from Edelbrock and it fits the universal Holley.Mancini or Summit can set you up with the carb and adapter.
Gus
64 Plymouth Savoy
Dana 60
383man [Re: fourgearsavoy] #686357
05/02/10 05:14 PM
05/02/10 05:14 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I prefer the Holley over the Carter and Eddy carbs in single carb application. But if you have a 500 hp Hemi I would use at least an 850 DP. The 750 will work but that eng will want more carb. Ron
Re: 383man [Re: 383man] #686358
05/02/10 06:40 PM
05/02/10 06:40 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I agree!
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Honest opinion. Holley DP or Carter [Re: Slipknot440] #686359
05/02/10 09:27 PM
05/02/10 09:27 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Why not try a tuning kit on the Eddy? Much cheaper than another carb.
I want my fair share
Re: Honest opinion. Holley DP or Carter [Re: Slipknot440] #686360
05/02/10 10:09 PM
05/02/10 10:09 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
What exactly is the eddy doing that you don't like?
Re: Honest opinion. Holley DP or Carter [Re: joedust451] #686361
05/02/10 11:37 PM
05/02/10 11:37 PM
Redding,CA USA
440charger500 Offline
Redding,CA USA
A hemi with only one carb just doesnt look right. I think it needs two.
Re: Honest opinion. Holley DP or Carter [Re: Slipknot440] #686362
05/02/10 11:39 PM
05/02/10 11:39 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If anything the 800 eddy may be too small
Re: Honest opinion. Holley DP or Carter [Re: 440charger500] #686363
05/02/10 11:44 PM
05/02/10 11:44 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I've run a bunch of Holley double pumpers and I liked every one of them. Had one Edelbrock 750 and didn't think much of it. I'd go 850DP with that motor.
Re: Honest opinion. Holley DP or Carter [Re: Ramrod39] #686364
05/02/10 11:53 PM
05/02/10 11:53 PM
federal way, WA
74chargr Offline
74chargr  Offline
federal way, WA
Carter=economy/reliability Holley=Better straight line performance. You never blow out a power valve on a carter. I have one on my 360 and it really sucks. But of course it is pretty beat so I can't really compare that to a new one. There is better fuel mixture on a carter because of the venturi design.
74 Charger SE 87 Shelby Lancer 80 1 ton bread box 71 Duster rest in pieces
Re: Honest opinion. Holley DP or Carter [Re: 74chargr] #686365
05/03/10 10:18 AM
05/03/10 10:18 AM
Dalton, MA
Dalton, MA
When my engine was dynoed with a 750 DP it made 504 hp with good power and tq through the run, an 850 DP made more power but less consistently, the Eddy made 498 hp but got a little to rich in the top end. Since the eddy has been in the car it doesn't seem to run at low speeds and idle as well as it should, but is great from 2500-5400 rpm. The engine builder was using his carbs for break-in and my carb for final tuning. He suggested the 750, as it is pretty much a stock 426 (as far as bore and stroke) and suggested that the 800 is a little big and the 850 would be too much. With his credentials I would believe anything he says.
Re: Honest opinion. Holley DP or Carter [Re: Slipknot440] #686366
05/03/10 10:46 AM
05/03/10 10:46 AM
Under My Car
Mopar_Country Offline
Under My Car
I'm curious about that. When the hemi's and max wedge engines were produced they had two 600 cfm carter afb carbs on them. I guess I would have to ask if they can handle 1200 total then why would an 850 be too big? I'm not a carb expert so there may be something I'm overlooking. Nice looking ride by the way.
Re: Honest opinion. Holley DP or Carter [Re: Mopar_Country] #686367
05/03/10 10:55 AM
05/03/10 10:55 AM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
I'd go with a Holley. The double pumpers can be a bit much for regular street use, but that hasn't stopped me from using one. My 440 makes about the same power that you're making and I have an 850 cfm double pumper. If you take this route you may have to jet the carb down a bit from the stock 80/80 jetting.
Good luck.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
