Re: Blew a trans line off...
[Re: Vert]
#685994
05/01/10 10:32 PM
05/01/10 10:32 PM
moparpollack
Lil Herman
Lil Herman
85086
Go get a compression fitting from the hardware store. Plumb it up so you won't get those nasty leaks.
[Re: TJP]
#686001
05/06/10 09:12 PM
05/06/10 09:12 PM
Posts: 4,950 WI
Dcuda69
WI
A double flaring tool will give you the bubble your looking for. Just bypass the second flaring operation
Do it all the time!!
[Re: TJP]
#686002
05/07/10 10:58 PM
05/07/10 10:58 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
Thanks! Exactly what I needed to know. Off to buy a flaring tool with the double-flare buttons tomorrow. I'd only done single flares (AN) before.
[Re: NITROUSN]
#686003
05/07/10 11:00 PM
05/07/10 11:00 PM
Vert
Annapolis, MD, USA
I hope the rubber hose was not fuel line. Most all fuel line and atf dont mix. The hose seems to soften up and wont stay on. There is a special hose for atf applications. Also as mentioned the EFI clamps work better.
Good to know also. Trans hoses came with the Trans cooler. And I'll look for the new style clamps and a tool. Thanks again Moparts Guys & Gals!
